1. MrClarenceCat's Avatar
    I had no issues using the Flash Player on my Samsung S3. I do a lot of home surveys for extra money and all of them are Flash based.
    I installed the old Flash Player .apk file but it will not work with the default browser.
    Any suggestions or help?
    10-17-2013 11:28 PM
  2. apquijano's Avatar
    Have you tried using Firefox?
    10-18-2013 12:04 AM
  3. humpagardengnome's Avatar
    Try this one, worked for me w/ the stock browser.
    http://download.macromedia.com/pub/f...17_archive.zip
    10-18-2013 02:56 AM
  4. john248's Avatar
    You can always try Puffin web browser.
    karsdroid likes this.
    10-18-2013 03:00 AM
  5. karsdroid's Avatar
    +1 on puffin.....worth the $2.99.....finally bought it and stopped fighting with downloading flash then trying to find just the right browser to use it with...
    john248 likes this.
    10-18-2013 12:22 PM
  6. DLCPhototography's Avatar
    Does Puffin Browser support sync of Google Bookmarks?
    10-19-2013 10:52 AM
  7. recDNA's Avatar
    It downloaded a zipped file containing many files, no app?
    Beamed from my Galaxy Note 3
    10-19-2013 01:35 PM
  8. recDNA's Avatar
    I have another flash player installed that works fine in dolphin browser. Is there a trick or setting to get it to work in stock browser?
    10-19-2013 01:37 PM
  9. William T Riker's Avatar
    Flash does not work with Chrome... I use Firefox personally.
    And that Flash in the pic is horribly outdated, current version is .81 get the newest one here: Archived Flash Player versions
    10-20-2013 04:52 PM
  10. cg101's Avatar
    First I downloaded Dolphin Browser, after installing .81 (Adobe Flash Player from previous post.) I followed the instructions to make it Desktop view, and the video in Amazon Prime worked fine in portrait, but when I went to landscape and in full screen, I would get a dark screen but audio would still play. So I switched to Firefox Beta (I figure this won't be terrible, since I will only use Firefox for Amazon Prime Video)
    This is the result:
    Agent Paulson coming to grab Tony Stark in the beginning of Avengers....the playback and rendering on the Note 3 is pretty sweet.
    This is a PITA to use though, but to watch Amazon Prime Videos...I could deal with this....
    10-20-2013 07:47 PM
  11. humpagardengnome's Avatar
    Not sure why the .apk didn't install for you but either way I was wrong, my apologies. I normally run flash off but I hit up a flash heavy site and just realized it's not working on Note 3 w/ stock browser. It's installed on my device but it's not active w/ either browser, stock nor Chrome for me. So I guess we all gotta do the alt browser route for flash plug-ins.
    10-20-2013 11:37 PM
  12. recDNA's Avatar
    There was no apk. Only a zipped folder cintaining more folders.
    10-21-2013 10:29 AM
  13. garyhare1969's Avatar
    Hi, when I downloaded your link it wouldn't let me open it, how are you able to do this please?
    12-20-2013 05:45 PM
  14. diver265's Avatar
    On Xscope browser flash works if its installed. Its loads fast too.
    12-27-2013 09:38 AM
  1. Replies: 30
    Last Post: 04-07-2018, 01:16 PM
  2. my galaxy note won't turn on
    By Nurul Rubyy in forum Samsung Galaxy Note
    Last Post: 02-21-2016, 04:39 PM
  3. Is this the place for the Galaxy Note 10.1?
    By Rob.G in forum Samsung Galaxy Note
    Last Post: 10-23-2013, 08:24 PM
  4. Update 4.3 - Email Issue (Cursor doesn't appear!)
    By incinerate2007 in forum HTC One M7
    Last Post: 10-17-2013, 10:36 PM
  5. Replies: 3
    Last Post: 10-17-2013, 09:58 PM
