04-16-2014 12:59 PM
39 12
tools
  1. KaCh0w's Avatar
    You know if you tend to struggle between LTE and 4G there is a good app that is worth trying called LTE Setting Quick Launch , it does for most a nice job of turning off LTE drains when 4G is often strongest in the area.
    10-26-2013 12:42 AM
  2. Shannon Zabroski's Avatar
    I had same prob as OP. I reformatted my phone on day 5... And was careful with how many google services I selected...and now my battery life is amazing. Can't believe the difference. I noticed my wife's S4 draining fast because of google services...and I reformatted hers too. Bam. Problem solved.
    10-26-2013 08:08 AM
  3. Preach2k's Avatar
    Has any of you guys turn of your NFC and beam? That will kill your battery.
    Sent from my SM-N900V using AC Forums mobile app
    10-26-2013 08:13 AM
  4. CompMan2012's Avatar
    I've been doing this for the past 2 years without any problems. I still have excellent battery life on my LTE iPad 3 that i purchased since launch. Also, My note 2 still goes 24 hours plus with a full charge from 0-5 %. I guess I'm the exception!
    10-26-2013 01:45 PM
  5. alexlam24's Avatar
    NFC is a low power process and doesn't require that much battery.
    Sent from Samsung Z1 GPE on T-Mobile
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-1382813334637.jpg
    10-26-2013 01:48 PM
  6. Preach2k's Avatar
    How to save Battery Life on The GNote 3. I am getting Great Battery Life may be this can help you guys having Battery Issues.
    10-26-2013 03:37 PM
  7. Preach2k's Avatar
    This thing has great Battery Life!!!
    10-26-2013 10:00 PM
  8. CompMan2012's Avatar
    Here's my battery screen shot.
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-1382873375502.jpg
    Preach2k likes this.
    10-27-2013 06:30 AM
  9. johnriii's Avatar
    not sure what your problem could be. from the day I turned on my S4, battery life has been above average to great. I'm a heavy user, and I still get a full day (0500-midnight) with about 35% to spare. I have turned off bluetooth and GPS, and a few other "gimmicky" things that I don't use, but in no way do I feel my phone is crippled. I have power saving mode on as well. I would assume the signal has a lot to do with how fast your battery drains, and I have a great signal on verizon. google maps can and will eat your battery, and I don't use Google now at all, as it was a drain, at least too much for my tastes. hopefully you'll get this figured out, because i have friends with the Note 2, and they can't burn through their battery, and they try. good luck to you.
    10-28-2013 11:33 AM
  10. Dirtdawg57's Avatar
    I have not been happy with my note 3's battery at all. I have rooted it and not only shut just about everything but I also locked down all bloatware and stuff I am not using. When it is not being used it does OK as it should but with what I consider very light usage it will just make it to bed time. With moderate usage it will make it about 10 hours. With heavy usage and god forbid games it is like 5 or 6 hours or less. Last night I played the new call of duty game and it took the battery from around 50 to 13% in about an hour. Today I have used it lightly for some web surfing and texting with the screen brightness as low as it can go. I am at 67% at 8 hours, which isn't terrible but that super light usage. I don't know about everyone else but I bought this beast of a phone to use, not to just leave on standby. I am not sure if have a bad battery or what but I have not liked it. Does anyone know when Samsung might release a extended battery? I am iffy about the aftermarket ones.
    10-28-2013 02:39 PM
  11. clevin's Avatar
    Dont let your battery die. It should only go down to the low battery threshold. For more info on this check out Foxkat's explanation on droidforums.net
    Sent from my SCH-I605 using Tapatalk 2
    This is calibration and should be done every 30-40 charging cycle, not every time.
    In every day use, both full charge and large depth of discharge should be avoided. Therefore, 30-80% is a better charging habit (charge to around 80%, start charging around 30%).
    All these are described at batteryuniversity, who run lab experiments to determine battery related questions.
    10-28-2013 05:35 PM
  12. The Hustleman's Avatar
    If you don't get better battery life than an iPhone on a note 3,theres a problem!
    10-28-2013 05:44 PM
  13. Dirtdawg57's Avatar
    Something weird I noticed. On the battery report it looks like the Gps has been left on but I have had it shut off all day. The blue means on right? Could it be sticking? Gps and location access are turned off.
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-screenshot_2013-10-29-14-30-33.jpg
    10-29-2013 02:08 PM
  14. Kymery o's Avatar
    I was reading all these sites about the battery dropping fast. I got my Note 3 about three weeks ago and just this week it started dropping fast, I would charge at 100 % before I go to sleep, and be woken up to an alarm that my battery is dead at 4am! I used to be able to last thru the next day while even using it to use fb and games etc. i turned off all sorts of stuff to find out what it was..but I found my Whatsapp was taking a lot. the very next day, I went to bed with 100% and woke up with 100%! now 11am and still at 89% and been texting all am for work. Some apps take up a lot of battery. delete, or turn off one by one until you find the one that is causing it. I do not think the upgrade has anything to do with the problem as I fixed my real quick.
    04-16-2014 12:59 PM
39 12
  1. Proximity Sensor problem in NOTE 3
    By Romil Majmudar in forum Samsung Galaxy Note 3
    Last Post: 02-24-2014, 12:00 PM
  2. Caller display not working in landscape mode
    By dakeb in forum Samsung Galaxy Note 3
    Last Post: 01-20-2014, 03:52 AM
  3. Galaxy Tab 3 - 90 degree cable to charge tab?
    By pjoseph in forum Samsung Galaxy Tab 3
    Last Post: 10-30-2013, 10:01 PM
  4. vzw ota update on my rooted gs4 help
    By ytsejam85 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 10-24-2013, 09:28 PM
  5. Replies: 1
    Last Post: 10-23-2013, 11:04 AM
