Catch the unveiling of the Huawei Mate40 series on October 22
04-16-2014 12:59 PM
39 12
tools
  1. jbrooks123's Avatar
    Good Morning all,
    I have had my Verizon Note 3 for about a week and it seems that im getting the worst battery performance. I had my phone plugged in last night when i went to bed ( phone charged to 100%) left for work this morning @ 100% its now quarter of noon & im at 53% WTF. anyone else having this issue, not sure if its a bad battery or just the usage of my device. I had an iphone before and battery life seemed to be much better. I love this phone but this issue has got to go.
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-1.jpg   5 days in to owning my Note 3 BATTERY SUCKING!!-2.jpg
    10-23-2013 10:54 AM
  2. ajonesma's Avatar
    So 18 hours with 53% left is known as battery sucking? Name another phone that can last that long.
    johnriii and wrich2005 like this.
    10-23-2013 11:04 AM
  3. jbrooks123's Avatar
    I know it shows that in the picture, but it is not realistic now its 12:26est and my battery% is at 40% down 13% in lest than an hour while my phone has been sitting on my desk
    10-23-2013 11:27 AM
  4. jrasero23's Avatar
    Something is wrong, and when I mean wrong I mean with what your reporting. The screenshot says 18 hours but your claiming to have reported this 11:45 but had it plugged in all night. There is no way possible of this happening
    johnriii and The Hustleman like this.
    10-23-2013 11:41 AM
  5. Almeuit's Avatar
    I'm also noticing no mobile signal.. In the graph but also in your screenshot. If you have no signal it's going to not help with battery life.
    Sent from my T-Mobile Note 3 using AC Forums.
    The Hustleman and cjsmoove like this.
    10-23-2013 12:53 PM
  6. alexlam24's Avatar
    Have you tried turning useless stuff off? WiFi, 4G, apps
    Sent from the last HTC device with a removable battery on T-Mobile
    10-23-2013 01:00 PM
  7. kanundrum17's Avatar
    I know my battery dies very quickly because i am in a 3g/4g area (both with like 1 or 2 bars) and it waste the battery trying to get signal. Anytime I am in a 4g area battery is perfect.
    10-24-2013 10:00 AM
  8. DINGSTER1's Avatar
    Ditto on this here in Md.
    Sent from my iPad
    10-24-2013 10:51 AM
  9. celticfdguy's Avatar
    If you don't have a good signal, your battery will DRAIN. This was the case at my job until they installed a repeater. Since then, my battery life is great. Put it into WIFI only mode.
    10-24-2013 11:34 AM
  10. dakeb's Avatar
    At least switch off mobile data.
    Sent from my SM-N9005 using Tapatalk 2
    10-24-2013 11:44 AM
  11. CompMan2012's Avatar
    I'm getting over a day of battery life with my 3. Try not leaving in on the charger all night. Once it's at 100% take it off. Also, let u battery drain out completely before you attach it to the charger.
    Like some of the other replies on this thread, when at work try turning off the bluetooth and wifi features if u are not using them. If u have wifi at your job and don't really use your cell phone, u can put it on airplane mode and turn on the wifi feature only and that will conserve battery life drastically. You can always toggle airplane mode off periodically to check voice messages.
    Good luck and i hope this is helpful for u!
    10-25-2013 06:03 AM
  12. newbroot83's Avatar
    Dont let your battery die. It should only go down to the low battery threshold. For more info on this check out Foxkat's explanation on droidforums.net
    Sent from my SCH-I605 using Tapatalk 2
    10-25-2013 06:24 AM
  13. alexlam24's Avatar
    Only let it drain periodically once a month. Otherwise you'll just be killing the battery. We use lithium ion, not NICD
    johnriii likes this.
    10-25-2013 06:41 AM
  14. newbroot83's Avatar
    Even once a month it shouldnt go lower than the low battery threshold. Its bad for the lithium batteries.
    10-25-2013 07:42 AM
  15. alexlam24's Avatar
    Maybe twice a year?
    Sent from Samsung Z1 GPE on T-Mobile
    10-25-2013 07:50 AM
  16. newbroot83's Avatar
    Maybe twice a year?
    Lmao. I never let mine go. Per Foxkat thats an easy way to shorten your battery's life. I follow strict guidelines with my battery so I can get the most from it.
    10-25-2013 08:28 AM
  17. missdorado26's Avatar
    What's a repeater?
    10-25-2013 10:19 AM
  18. Preach2k's Avatar
    I have gotten 2 days on a single charge on my Note 3 and at least a Day and a half...
    10-25-2013 10:39 AM
  19. Preach2k's Avatar
    This is what I got for today. I just finished using my phone on the overhead.
    Sent from my SM-N900V using AC Forums mobile app
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-1382719407527.jpg
    10-25-2013 11:43 AM
  20. sweetwil23's Avatar
    I ordered the hyperion 6400mAh extended battery off amazon, I've always purchased Seidio extended battery since the ****ty Hero came out and i have to say that this by far is better than the seidio because of the longer life, still slim and half the cost. This lasts me all day with no worries and high usage. Might want to order one yourself.
    Good Morning all,
    mcat66 likes this.
    10-25-2013 05:16 PM
  21. jrasero23's Avatar
    Getting close to 12 hours on and with little over 50 percent left and did almost 3 hours screen time. Not bad but this is S4 battery for me on verizon. I think me working in a basement with 1 or 2 bars doesn't help. This weekend I will test since where I live has better service
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    Attached Thumbnails 5 days in to owning my Note 3 BATTERY SUCKING!!-1382741236265.jpg   5 days in to owning my Note 3 BATTERY SUCKING!!-1382741259031.jpg
    10-25-2013 05:49 PM
  22. Preach2k's Avatar
    I don't want a thick battery and back for my Gnote3. I have been getting good battery time with mine.
    10-25-2013 06:45 PM
  23. Jay Sacks's Avatar
    Don't worry about leaving your phone on the charger all night. The battery will stop charging at 100%. One of the best ways to kill your lithium ion battery is to let it fully discharge. Read up.
    Sent from my SCH-I605 using AC Forums mobile app
    newbroot83, apquijano and johnriii like this.
    10-25-2013 06:53 PM
  24. 8tech's Avatar
    My understanding of it is a device that takes a wireless signal and broadcasts (repeats) the same signal so that the other "side" of the repeater can get the signal. Its used so the range can be extended to those who can't get the signal without it.
    10-25-2013 10:09 PM
  25. jnugglet's Avatar
    I had this same problem starting at about day 10. Easy fix. Settings->Location services->access to location-> Off. This one change alone has made my battery life stellar.
    10-25-2013 11:25 PM
39 12
  1. Proximity Sensor problem in NOTE 3
    By Romil Majmudar in forum Samsung Galaxy Note 3
    Last Post: 02-24-2014, 12:00 PM
  2. Caller display not working in landscape mode
    By dakeb in forum Samsung Galaxy Note 3
    Last Post: 01-20-2014, 03:52 AM
  3. Galaxy Tab 3 - 90 degree cable to charge tab?
    By pjoseph in forum Samsung Galaxy Tab 3
    Last Post: 10-30-2013, 10:01 PM
  4. vzw ota update on my rooted gs4 help
    By ytsejam85 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 10-24-2013, 09:28 PM
  5. Replies: 1
    Last Post: 10-23-2013, 11:04 AM
