1. maxzeff's Avatar
    I bought the note 3 yesterday because the screen on my 2 stopped working and I had an upgrade. The verizon store only transferred the contacts from my google accounts and not the contacts I had saved on my phone. When I went back to ask them to they said it was impossible without being able to navigate the note 2 screen. The note 2 still turns on and works, the screen is simply off at all times. Is there some way to transfer the info from my old not 2 to my new note 3? Verizon claims its impossible unless I get the screen fixed but I am hoping there is some way to do it through my computer. Any help would be greatly appreciated. Thanks
    10-23-2013 11:17 AM
  2. ccpopham's Avatar
    Did you use the verizon backup? It is usually on by default because it is free or it may have been on and you didnt notice it. Anyway on the note 3 go into settings-》accounts-》backup assitant plus and check the sync box. You can go onto you verizon wireless account online too and find backup assistant there and see if any contacts are there. My old phone bricked and for some reason some of my contacts were in google and some were in the verizon assist and some in both. I was not sure why it worked like that but between the two I got all of my contacts back.
    Sent from my SM-N900V using AC Forums mobile app
    10-23-2013 11:28 AM
  3. TheMaskedMamba's Avatar
    They're apps that you can install on your desktop the will allow you to backup contacts. The app name escapes me but I know it exists
    Sent From "The Beast"
    10-23-2013 11:29 PM
  4. dt81's Avatar
    He cant use them since he can't see anything on his note 2 screen. If they are not backed up with Verizon back up I'm pretty sure that you are SOL :-/
    TheMaskedMamba likes this.
    10-24-2013 05:42 AM
  5. Fairclough's Avatar
    If the digitiser works, unlock it blind or using wondershare mobile go you can see what would be on the screen to navigate than once its unlocked you can just back up and transfer.
    I do believer mobile go requires you to have developer debugging on
    - Android Central App. Remember courage is contagious.
    10-24-2013 06:26 AM
  6. watalee's Avatar
    Install a software named wandoujia,it will help you to backup everthing in your note2 and then restore into your note3
    Sent from my BlackBerry 9930 using Tapatalk
    10-24-2013 06:27 AM
  7. TheMaskedMamba's Avatar
    No not true, the only caveat would be if is phone is pin locked, but if not the app with still work, trust me I used one a long while back, it read contacts and photos. just can't remember the name.
    10-24-2013 04:28 PM
  8. dt81's Avatar
    Oh, well Im sorry. I was wrong.
    10-25-2013 06:50 AM
  9. watalee's Avatar
    what do you feel about my registered name?my friend
    Sent from WATA's Note2
    10-25-2013 07:21 AM
  1. Replies: 5
    Last Post: 05-03-2014, 11:46 PM
  2. 5 days in to owning my Note 3 BATTERY SUCKING!!
    By jbrooks123 in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-16-2014, 12:59 PM
  3. Replies: 7
    Last Post: 11-15-2013, 07:27 PM
  4. Galaxy Tab 3 - 90 degree cable to charge tab?
    By pjoseph in forum Samsung Galaxy Tab 3
    Last Post: 10-30-2013, 10:01 PM
  5. Replies: 4
    Last Post: 10-23-2013, 11:44 PM
