...We're supposed to be able to use the same app in the split window screen... what a load of crap!
has anyone else noticed this?????
I have yet to really play with it. The one time I did it worked as advertised.
Mine works fine.
Seriously? Then mine is the only one not working properly? I can't believe that.
Let me explain this one more time...
I'm trying to use the same exact app on a split screen... Meaning I want to have 2 separate text messages sessions going on at the same time!
Sent from my SM-N900V using AC Forums mobile app
not all apps will do it only Internet and Some chat apps,according to help on multi window,
I'm trying to do it with the native texting app like they demonstrated
Have you tried toggling Multi-Window off and then back on again in the notification toggles?
Than what is this below? It's two internet browser windows.Sorry .... ALL of us are confused ..... you want to run 2 browsers or 2 facebooks at the SAME time .... just tried that & you cannot run 2 of the SAME apps at the SAME time Bummer Dude! & I doubt any of the others can do this either Maybe they will look at this thread & say "Give it to them"
Cheers, Jon
It does work with internet browser and it says some texting apps. I opened to web browsers from multiwindow without a problem.
