Issue Opening the Same App Twice in Multi Window
CompMan2012
Banned
Jun 10, 2013
275
Mine works fine.
Seriously? Then mine is the only one not working properly? I can't believe that.
Let me explain this one more time...
I'm trying to use the same exact app on a split screen... Meaning I want to have 2 separate text messages sessions going on at the same time!
Sent from my SM-N900V using AC Forums mobile app
ccpopham
344
not all apps will do it only Internet and Some chat apps,according to help on multi window,
Haalcyon
Banned
Jul 19, 2013
7,662
I opened one window, then opened a message app in the second window, then switched. Not sure why I had to do it that way but worked just as easily.
ccpopham
344
On my Note 8 which is rooted I have a multi window app that is from the app store which allows a lot more Versatility with the Multi window I have not yet rooted My note 3 to try it On here yet,
GtoJon
368
3
18
Sorry .... ALL of us are confused ..... you want to run 2 browsers or 2 facebooks at the SAME time .... just tried that & you cannot run 2 of the SAME apps at the SAME time :( Bummer Dude! & I doubt any of the others can do this either :p Maybe they will look at this thread & say "Give it to them" :D
Cheers, Jon
Haalcyon
Banned
Jul 19, 2013
7,662
Cheers, Jon
Than what is this below? It's two internet browser windows.
ccpopham
344
It does work with internet browser and it says some texting apps. I opened to web browsers from multiwindow without a problem.
GtoJon
368
3
18
I just found that out ... non of the others in the Multi-Window bar will work that I have seen :( Kinda sucks when you can't depend on something that should naturally work!!
Cheers, Jon
Finsrepair
