1. anon8126715's Avatar
    I just noticed this recently and figured I'd share with everyone else. I used to always get "VZ Navigator has stopped unexpectedly" on my screen and wanted to know if anyone would get the same random message. I went ahead and killed the app (and was surprised that it let me uninstall). Hopefully this will only add to my battery life. I don't remember ever activating it either since I'd rather use Google Maps which is free anyways.
    10-28-2013 01:40 PM
  2. ferndog75's Avatar
    I haven't seen anything like that. It is always running in the background on mine since I check it and always have to Force Stop it. I can see that you can Turn Off the app but how did you uninstall it?
    10-28-2013 04:37 PM
  3. anon8126715's Avatar
    I went to "All" under App management, and saw 2 listings for it. The 1st one let me remove the updates, and disable it. The 2nd listing let me actually delete it. I'll post up a screenshot of my app list.
    10-28-2013 04:54 PM
  4. GtoJon's Avatar
    I could select "Turn Off", but no other option in application manager. Now I can only find it in the "Turned Off" section
    Cheers, Jon
    10-28-2013 05:26 PM
  5. ccpopham's Avatar
    Maybe that was the issue where youbsaid it was listed twice. I have never seen vz nav listed twice on any of my phones.
    Sent from my SM-N900V using AC Forums mobile app
    10-28-2013 05:29 PM
  6. anon8126715's Avatar
    Cheers, Jon
    Have you done any updates for that app? I was actually surprised that I could remove it as well considering I had a Rezound for almost 2 years and it wouldn't let me remove that piece of garbage app unless I was rooted. I'm not rooted right now either.
    10-28-2013 07:23 PM
  7. anon8126715's Avatar
    I figured I'd check some other apps, and I think I've figured out why I had duplicates. I used a backup application to backup my apps from my Rezound to my N3. I think installing Verizon Navigator and NFL Mobile from my Rezound gave me an option to delete these apps. If that's the case, I'm going to look for other Verizon Bloatware that I can install from my Rezound so I can delete.
    10-28-2013 07:35 PM
  8. GtoJon's Avatar
    I knew uninstall update would just go back then nag me forever about updates so I decided to choose "Turning Off" & it removed the update .... weird ..... then I had to turn it off again. Now it no longer shows up in my apps, except in a new Turned Off section
    Cheers, Jon
    10-28-2013 08:04 PM
  9. anon8126715's Avatar
    Cheers, Jon
    Sigh way to kill my buzz, I remember seeing that tab before, but it didn't occur to me to look there. At least now I figured out why I had duplicate entries. I'm almost tempted to root this thing just to get this Verizon bloatware off of this phone.
    10-28-2013 08:09 PM
  1. Note 3 sync and backup issues
    By olues in forum Samsung Galaxy Note 3
    Last Post: 03-21-2014, 05:46 PM
  2. Anyone dropping the Note 3 to go back to the S4 once 4.3 hits?
    By CompMan2012 in forum Verizon Samsung Galaxy Note 3
    Last Post: 11-05-2013, 11:28 AM
  3. I'm dumping my note 3 for my S4 once the 4.3 update hits!
    By CompMan2012 in forum Verizon Samsung Galaxy S4
    Last Post: 10-31-2013, 09:05 AM
  4. Adjusted to the Size...........of other phones
    By sal the wop in forum Samsung Galaxy Note 3
    Last Post: 10-30-2013, 12:14 AM
  5. I dropped the Spen down the toilet
    By richard hodge in forum Samsung Galaxy Note 2
    Last Post: 10-29-2013, 02:23 PM
