The note 3 is great but a bit buggy. Anyone know if we are due an update to resolve some of the common bugs? Otherwise the g2 is half the price (got on upgraded) and as far as I know not as buggy
You can't launch 3rd party notifications from the lock screen. When you click on the notification the app launches but the phone doesn't unlock. So you sit at the lock screen till you swipe to unlock. Then you're in the app already.
Are you using Touchwiz? That may be the issue... I just emailed myself from my work email just now. The phone received the push (it vibrated)... So I dragged down the notification bar and tapped on the email. Gmail opened right to the message... When I hit the back button it took me to my inbox in Gmail. The phone is unlocked.
I use Nova Launcher (prime). Also another thought... Do you have a password on your phone?
Sent from my T-Mobile Note 3 using AC Forums.
Yes I'm using touchwiz. I'll try a different launcher
Nova didn't change the lock screen
No password. And when I install nova and click the power button I'm back at the touchwiz lock screen
