1. maya707's Avatar
    Hello people. Is the Verizon version of the Note3 capable of playing high resolution audio files like 24bit/192khz FLAC like the LG G2? What about WAV files? Has anyone done this yet? If so, could you please comment on the quality experienced? Thank you all!
    10-30-2013 07:30 PM
  2. maya707's Avatar
    Hello? Hello? Aren't there any audio geeks out there in note3 land? Hello?
    10-31-2013 02:09 PM
  3. ccpopham's Avatar
    I use the power amp app which can play flac files and many other files.
    Sent from my SM-N900V using AC Forums mobile app
    10-31-2013 02:26 PM
  4. maya707's Avatar
    Maybe I'll just go that route...PowerAmp or Neutron
    10-31-2013 03:46 PM
  5. ccpopham's Avatar
    Yeah I have never been one for the stock apps usually and have had power amp for years.
    10-31-2013 04:06 PM
  6. maya707's Avatar
    Thanks much!
    10-31-2013 07:24 PM
  7. ccpopham's Avatar
    Your welcome. Power amp has a trial too so you can check and see if it meets your needs.
    10-31-2013 07:48 PM
  8. maya707's Avatar
    I had the trial version of PowerAmp on my Droid Bionic for a couple of days before the phone started getting weird and I had to FDR back to nakedness. I only put back a few apps and photos to keep things slim and trim so I never got to really try it out. Worth another trial and seems like the way to go. Thanks for the tips!
    11-01-2013 03:05 PM
  9. ccpopham's Avatar
    NP
    11-01-2013 04:57 PM
  1. YouTube Audio for Embedded Videos!?
    By nexus10802 in forum Google Nexus 10 Tablet
    Last Post: 05-05-2016, 03:00 PM
  2. is there a way to turn the audio notifications off while on the phone?
    By Marcus Foldy in forum Samsung Galaxy S4 Active
    Last Post: 10-30-2013, 12:51 PM
  3. No audio when paired to 2013 equinox MyLink radio
    By busterviews in forum HTC EVO 4G LTE
    Last Post: 10-25-2013, 10:56 PM
  4. Audio Stops Playing Suddenly
    By eptiger in forum Samsung Galaxy S II
    Last Post: 10-24-2013, 11:10 AM
