Verizon Samsung Galaxy Note 3 - Samsung Support Tip To Solve 99% Of Phone Glitches
James Giove
6
FIRST STEP:
Settings>Application Manager>All>Select Problem APPS and CLEAN CACHE AND DATA on what ever apps are giving u an issue.
SECOND STEP:
POWER DOWN PHONE
PULL BATTERY WAIT 20 SECONDS
INSERT BATTERY AND COVER
ENTER RECOVERY MOD BY "HOLDING TOGETHER VOLUME UP, POWER, HOME BUTTONS TILL VIBRATE AND SAMSUNG SPLASH SCREEN RELEASE ONLY POWER BUTTON
WHEN RECOVERY MOD SCREEN APPEARS RELEASE ALL BUTTONS.
SCROLL DOWN WITH VOLUME KEY TO "WIPE CACHE PARTITION" SELECT USING POWER BUTTON
THEN SELECT REBOOT SYSTEM AND PROBLEMS SHOULD BE SOLVED
James Giove
6
Its not hard to do, it takes about 3 minutes to do. While in the camera app, the screen was stuck on landscape and wouldnt rotate. Then my LED Flash wasnt working for the camera flash or the flashlight app. these steps fixed my problems
TheMacs
474
10
Powering down works 99% of the time. 99% of the rest of the time, a battery pull usually works.
The rest of us are most likely already rooting, flashing roms, etc., etc.
