I locked myself out and forgot PIN number - Help please
Casey Cheung
1,234
5
I was screwing around with security settings, and inadvertently changed my PIN number to something different on my Note 3 phone. Now I'm locked out as I don't know what exactly is the changed PIN number. I can't access my phone now. Duh!! Anyone have a solution other than doing a hard reset?
EDIT: Screen now says you have incorrectly typed your PIN 25 times, please wait 30 seconds to try agin. I'm not seeing any other alternatives to access my phone.
Thanks!
Casey
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Do you have your Google account on your phone?
Sent from my T-Mobile Note 3 using AC Forums.
yarnsrj
619
Hard reset bro. My step daughter did the same and couldn't remember the pattern. Call verizon but I'm pretty sure they're gonna tell you the same. Or keep trying the pin.
from "Ms Note 3"
Almeuit
Moderator
Apr 17, 2012
32,277
23
Yes, I have a Google account, but that option is not showing up to ask me about it.
Login to Android device manager on a PC via your Google account.. From there you can setup a password which will overwrite the existing one.
pcbtmr
249
6
Could you elaborate on this please? Is "Android device manager" a website for logging into, an application to download and from where? Is this something that TMO provides but not VZW?
Almeuit
Moderator
Apr 17, 2012
32,277
23
lterry913
443
18
I don't know for sure but I think you have to allow android device manager to have control of your phone in phone settings under security>device managers...otherwise it will not have permission to access the phone.
I could be mistaken. Someone may correct if I am wrong.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
You are correct.
Sent from my Verizon Samsung Galaxy Note 3
lterry913
443
18
So android device manager will not let op into phone because it can not be made an administrator due to the fact he/she can't get into phone... Op will have to probably contact service provider to get them into phone so they can prove it is their phone.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
That is correct, it would have to be set up before hand. I agree contacting the carrier is the best bet now, if adm isn't set up
Sent from my LG G Pad 8.3
kerokekerol
