1. NJ Fred's Avatar
    My hearing is not what it used to be. Aging - it happens to all as the years pile on.
    I am looking for an application that will effectively increase volume on telephone calls. I often have problems hearing callers even when conversing in quiet surroundings. I rarely listen to music, etc. so that is not my focal concern.
    Any guidance will be deeply appreciated.
    09-28-2014 10:09 AM
  2. Neal Smith's Avatar
    The only thing I know of You can do to increase volume on you phone You would have to be rooted for it to work.
    09-29-2014 10:17 AM
  3. conanheath's Avatar
    This is no answer for your question but have you thought about a bt headset? I have the same problem and work in noisy environment and use LG's stereo bt ear buds.(forgot model but it's the ones that sit on your shoulders) I can put in both buds and hear what's going on. Or just regular wired ones even. Hearing convo in stereo makes all the difference in the world. Just a thought.
    10-01-2014 06:04 PM
  4. B3t0's Avatar
    My note 3 earpiece just got to low on the volume calls... this is new... it was working perfectly but since yesterday i can barely hear the one who is calling me... any clues???
    02-16-2015 09:08 PM
  5. hmfoster's Avatar
    Did you check the volume on the phone, might just be the control on the left side got pushed down.
    02-17-2015 04:46 PM
  6. PoisonDarts8714's Avatar
    As above, make sure volume is all the way up. There actually is a button to raise volume. Directly above end call.
    See:
    02-19-2015 02:59 PM
  1. Can anyone help me get my Tab 3 to turn on?
    Last Post: 11-25-2014, 11:44 PM
  2. Is there an app that will increase the volume on my phone?
    Last Post: 09-28-2014, 11:09 AM
  3. Why won't the volume on my phone speakers play loudly?
    Last Post: 09-28-2014, 12:09 AM
  4. Replies: 0
    Last Post: 09-27-2014, 02:06 PM
  5. Replies: 1
    Last Post: 09-27-2014, 01:36 AM
