Hi folks.
I posted the same question long ago, but I thought maybe enough time had gone by where somebody has perhaps figured out a fix for it.
I've had my Note 3 since February, but the Bluetooth never worked in my older (2003) BMW. It will pair successfully, but it will continuously connect and disconnect over and over again. I understand that the OS update did not include certain Bluetooth code required for compatibility with older Bluetooth systems, but is there any way to install an older Bluetooth stack without rooting the device, Or are there any other workarounds that might allow this to work? Updating the software in the car is cost prohibitive (A replacement ULF costs about $400).
Are my choices still rooting and installing CM (I'm not Interested in rooting), Replacing the hardware in my car, or hoping and waiting for Google to fix the problem?
Any advice would be welcomed and appreciated.
Thanks!
TONY
Thanks!
TONY
