Case options with charging cover
mcongdon
Has a anyone been looking for or had any luck finding a case to fit the Note 3 with the Samsung wireless charging back cover installed?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Not a good one, which is why I installed a Qi receiver under the stock cover (taped to the phone just above the battery, so I could remove the battery without disturbing the placement of the receiver) to use the phone in an Otterbox Defender. It still makes it difficult to remove the case, but it works.
thtknt
