04-15-2015 08:57 PM
46 12
tools
  1. Linda McDonald's Avatar
    That's what I heard. Jan. Feb. May?
    01-22-2015 02:49 AM
  2. chuckr01's Avatar
    Don't get took excited about Lollipop and wait until you find that an update is stable before you jump in. The 5.0 update on my Nexus 7 was a major pain and the 5.0.2 update finally made it better. My Note 3 is working fine now after the last update with 4.4.4 and the last update fixed battery issues, so I am happy, leave it be.
    Jalopiejoe likes this.
    01-22-2015 08:16 PM
  3. PoisonDarts8714's Avatar
    Given how long it took for us to get Android 4.4.4..Maybe mid 2015. And seeing some of the initial rollouts on other smartphones/tablets, I wouldn't be rushing to download it anyway.
    01-23-2015 01:11 AM
  4. Linda McDonald's Avatar
    Whatever comes on my phone is what stays on my phone. Updates are dangerous.
    01-23-2015 12:07 PM
  5. Haalcyon's Avatar
    I'm not caring about Lollipoop at all. I want it to perform as good or better than Kit Kat does now. That's all I ask. ...otherwise, they can keep it...forever.
    01-23-2015 12:43 PM
  6. PoisonDarts8714's Avatar
    Wish I could say the same! Didn't root when I had the chance.
    01-23-2015 01:08 PM
  7. SweetWater56's Avatar
    First 4.4.4 fixed all my issues on my Note, 2nd 4.4.4 update completely screwed it up and am now dealing with the same issues I had pre 4.4.4. Bring on 5.0.1 or 5.0.2
    02-02-2015 12:33 PM
  8. Haalcyon's Avatar
    Huh?
    02-02-2015 01:01 PM
  9. SweetWater56's Avatar
    Huh?
    I had major wifi connectivity issues pre on jelly bean then the first 4.4.4 update fixed everything then verizon released the 2nd update and now I have connection issues again
    02-03-2015 03:22 PM
  10. Haalcyon's Avatar
    Have you tried wiping the cache in recovery?
    from the 3
    02-03-2015 03:24 PM
  11. SweetWater56's Avatar
    from the 3
    I've tried everything. Some Notes just dislike the last 4.4.4 update. Not all just some.
    02-04-2015 09:51 AM
  12. mickeyboat's Avatar
    from the 3
    How do you do that?
    02-17-2015 04:08 PM
  13. Haalcyon's Avatar
    How do you do that?
    On a Samsung phone:
    1. Turn the power off.
    2. Press the volume up+home+power keys until you feel the phone vibrate.
    3. Release the power and home keys but continue to press the volume up key until you enter the Recovery menu.
    4. Use the volume up or down keys to navigate and the power key to select the 'wipe cache partition option.
    5. Select 'Reboot' when done.
    from the Note Edge📱✒
    02-17-2015 05:11 PM
  14. terryb99's Avatar
    Don't get excited. The 5.0 upgrade has been a horrible experience on my S5.
    I told my wife, if you get a pop up on your Note 3 taking about an upgrade, press no way in hell, lol.
    03-05-2015 06:32 AM
  15. Haalcyon's Avatar
    I've had Lollipop on my G3 since the day I got it a week and a half ago. It's been perfectly fine but also absolutely nothing whatsoever to feel anxious or excited about. I just don't understand why some are so anxious to get it. TBH, I don't really care for the new notification pull-down.
    🔋from the Note 4✒ 📒
    03-05-2015 07:17 AM
  16. Baby_Doc's Avatar
    Does anyone know if 5.0 will allow writing to the SD card? Rumor was it might
    03-05-2015 09:19 AM
  17. Haalcyon's Avatar
    Yes it does.
    ♻from the Note 4✒ 📶
    03-05-2015 10:33 AM
  18. terryb99's Avatar
    from the Note 4✒
    I think the difference being, new install, vs all us poor saps upgrading from 4.4, lol
    03-08-2015 02:27 PM
  19. terryb99's Avatar
    🔋from the Note 4✒ 📒
    03-08-2015 02:27 PM
  20. LiveFaith's Avatar
    This is my question. Does this 5+ update really have any productivity value? I honestly cannot see it.
    I have 4.4.4 on my Note 3 VZW and it is flawless in my usage. Notifications and multitask are no more intuitive, if even equal IMO. Not seeing a real reason to leave the KNOWN for the UNKNOWN when the update comes available.
    03-13-2015 10:38 AM
  21. Haalcyon's Avatar
    Productivity value? None that I could discern.
    ♻from the Note III🍶
    03-13-2015 11:39 AM
  22. contrasteve's Avatar
    Damn I'm glad I didn't hold my breath.
    03-13-2015 06:22 PM
  23. Baby_Doc's Avatar
    ♻from the Note III🍶
    If Lollipop allows you to write to your SD card again, that would be enough value for me.
    yarnsrj likes this.
    03-14-2015 09:36 PM
  24. Jalopiejoe's Avatar
    My Note 3 has been running Great on KitKat 4.4.4 NK1.
    I really don't like the idea of updating to Lollipop, I'd rather not!
    Wish there was a way not to take the update other than rooting, that I will not do!
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    anon8380037 likes this.
    03-14-2015 10:58 PM
  25. SweetWater56's Avatar
    Lollipop update is scheduled for a July release. So I'm sure it'll be out in December or maybe November knowing big red.
    03-17-2015 12:14 PM
46 12
  1. Replies: 7
    Last Post: 01-30-2015, 02:01 PM
  2. When will I get update for my Micromax a121 of Lollipop 5.0?
    By krishna mugutkar in forum Android 5.0 Lollipop
    Last Post: 01-25-2015, 01:05 PM
  3. First, I had Lollipop, now - I don't! What are my options?
    Last Post: 01-22-2015, 01:35 PM
  4. Replies: 2
    Last Post: 01-22-2015, 03:11 AM
  5. Replies: 0
    Last Post: 01-22-2015, 01:43 AM
