1. recDNA's Avatar
    I have the VZW wireless charging stand and my note 3 has the samsung wireless charging battery cover installed. It all works fine except gSam shows it only charges at 640 mA. VZW claims it charges at 1000 mA. Of course at that charge rate it takes forever to charge the battery in a note 3. If you have a wireless charger could you check with gSam or some other app that shows charging amps could you report what yours says? Of course I am interested in the same stand I have in case mine is defective but I'm also interezted in the tylt vu stand or any other you might have. Thanks!
    04-03-2015 12:20 PM
  2. Rukbat's Avatar
    The stand is capable of supplying 1000mA. Charging receivers draw 640mA. So both numbers are correct. (If you plug a 100 Watt [approximately 1 Amp] light bulb into a 30 Amp outlet, it's not going to draw 30 Amps.)
    640mA (I'm looking at the Galaxy Charging Current app right now) on wireless charging, 1200mA on the Samsung wall charger, about 450mA on USB.
    In this case, Verizon isn't lying, they're just reading the label. (My charging plate is also rated 5 Volts at 1000mA output on its label. The Note 3 still charges at 640mA.)
    04-03-2015 06:08 PM
  3. recDNA's Avatar
    Thanks. I never could find tech specs for the receiver
    04-03-2015 11:20 PM
  4. recDNA's Avatar
    Does nexus 6 work on vzw stand?
    04-07-2015 04:58 PM
  1. S6 car charger
    By Kalvin Kerns in forum Samsung Galaxy S6
    Last Post: 08-11-2016, 11:51 PM
  2. OTA Update for Verizon GS5 - FoxFi Still Working?
    By RFclipse in forum Samsung Galaxy S5
    Last Post: 08-02-2015, 11:34 AM
  3. Nexus 6, Verizon, and Google Voice voicemails not working
    By tysdroid17 in forum Google Nexus 6
    Last Post: 04-17-2015, 06:04 PM
  4. Is wireless charging included in stock Nexus 5?
    By AC Question in forum Google Nexus 5
    Last Post: 04-16-2015, 08:26 AM
  5. What kind of charger can I use for my tablet?
    Last Post: 04-03-2015, 06:31 PM
