1. PoisonDarts8714's Avatar
    I downloaded the NK1 firmware and flashed it using odin. This may be above some of the users here, but basically it reflashes everything...so backup your data before you do this because it will be basically a factory reset.
    Of note-on initial restart post flash the device bootlooped. I pulled the battery and went into recovery and hit factory reset. This worked, and I'm now back on 4.4.4 NK1.
    I don't know if I can post links from XDA on here, but if it's allowed I will. There's an entire thread on it..with instructions.
    When Verizon releases the next update for the Note 3, they'll almost certainly blacklist NK1..if you ever want 4.4.4 back do not take the next OTA unless it's stable.
    I lost some LTE signal strength, and Samsung Keyboard crashed randomly (yes I reset) prior to update I got -115db of LTE at work (large office building steel structures, -105db outside so it's not that great anyway. On Lollipop it stuck with 3g even if I did the airplane mode dance at work.
    anon(96159) likes this.
    05-12-2015 12:38 AM
  2. B. Diddy's Avatar
    Thanks for letting us know! Here's a guide on AC on how to flash using Odin: http://forums.androidcentral.com/amb...interface.html. Firmware can be found here: Firmwares - SamMobile
    05-12-2015 01:46 AM
  1. Moto e 2nd gen user , how is your moto e user experience
    By gfederline9 in forum General News & Discussion
    Last Post: 05-12-2015, 11:52 AM
  2. Replies: 0
    Last Post: 05-12-2015, 12:29 AM
  3. Replies: 0
    Last Post: 05-12-2015, 12:15 AM
  4. Replies: 1
    Last Post: 05-12-2015, 12:02 AM
  5. Replies: 0
    Last Post: 05-11-2015, 10:21 PM
