1. AC Question's Avatar
    reset do to too many wrong unlock pin attempts, which reset my phone. now during setup wizard it is looping back to the beginning.
    04-06-2017 06:19 AM
  2. donc13's Avatar
    Since your phone was rooted, a factory reset doesn't always work. You are going to have to flash it from a stock firmware download.
    All the firmware is on sammobile.com,you have to be a member to download but membership is free. You will also need Odin for your PC and a link for that and instructions are also on sammobile.
    Your other option is to completely power off the phone. Remove then replace the battery then start the phone in recovery mode (vol UP, home and then power key all held down until the phone starts. Once in recovery, select the full factory reset option.
    That may not work.
    04-06-2017 07:31 PM
  1. Replies: 1
    Last Post: 04-06-2017, 07:59 AM
  2. Why is my screen not sensing my touch?
    Last Post: 04-06-2017, 07:58 AM
  3. i need help with my rooted verizon note 3 PLEASE.
    Last Post: 04-06-2017, 06:18 AM
  4. My Samsung S5 g900i speaker turn on when recive and forward call?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-06-2017, 05:55 AM
  5. Replies: 0
    Last Post: 04-06-2017, 05:51 AM
