1. felloffthetruck's Avatar
    they did with the Note 2?
    I never had the S3 so I'm not sure if the WiFi settings were normal or Verizonized on the S3?
    05-09-2013 10:28 AM
  2. lindseybp's Avatar
    What was screwed up on the note 2 wifi swings?
    Sent from my SCH-I605 using Android Central Forums
    05-09-2013 10:35 AM
  3. phantomog's Avatar
    nothing wrong with my Verizon Note 2 wifi settings...
    05-09-2013 11:15 AM
  4. felloffthetruck's Avatar
    I mean where the WiFi toggle setting has been removed from the top of the notifications panel and continually bugs you to turn on WiFi every time you are near a signal.
    AT&T or none of the other carriers do this. Just something that bugs the crap out of me.
    05-09-2013 12:44 PM
  5. japetty's Avatar
    It is not in the notification of the S3. With VZW they let you know when wifi is within range so you can switch to wife if you are not on unlimited data and save your data for use when you are not near a wifi. You are going to find the S4 on VZW to be the same. I just pay no attention to it as I have unlimited data on 4G but if I have something slower I would switch to wifi. That may be the normal setting and the others changed it so you run over your data allotment often and they collect more money from you.
    05-09-2013 01:49 PM
  6. infinity12402's Avatar
    im pretty sure they did it just because they can, seeing as how they also removed the blocking mode from the phone...
    05-12-2013 03:21 PM
  7. ibcop's Avatar
    You can add the blocking mode.
    05-12-2013 05:37 PM
  8. infinity12402's Avatar
    i know you can download third party apps that do the same, but i just dont understand why it was necessary to remove it to begin with.
    05-12-2013 08:28 PM
  9. ibcop's Avatar
    Very simple to do:
    1. Download QuickShortcutMaker from the Play store. [Play Link]
    2. Open the app and search for blocking mode.
    3. Two results should pop up, tap on the first one.
    4. On the next screen, name the shortcut and then tap OK.
    5. You will now have a shortcut to Blocking Mode on one of your home screens.
    6. Tap the shortcut to open up the Blocking Mode menu.
    05-12-2013 08:39 PM
  10. Joe the Insider's Avatar
    I will confirm this as soon as we receive the store display units.
    05-13-2013 12:27 AM
  1. Have Moto and VZW just given up on the Bionic?
    By rduckwor in forum Droid Bionic
    Last Post: 02-02-2012, 11:04 AM
  2. will the Droid usb-keyboard hack work on the Evo?
    By Braaainz in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-16-2011, 10:55 PM
  3. Will Vibrant have UMA (Wifi Calling)?
    By whitenack in forum T-Mobile Vibrant
    Last Post: 12-07-2010, 10:02 AM
  4. Is there a way to set a "bedtime" mode on the Droid X?
    By TurboCam in forum Motorola Droid X
    Last Post: 07-30-2010, 02:42 PM
  5. Can changing the boot screen animation screw up the phone?
    By ilaifire in forum Software Development and Hacking
    Last Post: 06-10-2010, 11:49 AM
