04-27-2015 12:06 PM
31 12
tools
  1. Meryl Weiner's Avatar
    I actually tried to remove the Caller ID app in my app manager (I picked "all" in the app menu). Oddly, it's not listed there. I ended up disabling it. I actually wanted to remove it, but since it's not listed in the app manager, I can't. Disabling it seems to have cleared up my issue with the 4G and WIFI icons being on at the same time, though.
    klynnfields likes this.
    05-07-2014 03:49 PM
  2. klynnfields's Avatar
    Annoying and REALLY hard to see what you are actually on when only the Bar is displayed. Naturally ALSO ANNOYING is that the S4 constantly has unstable WiFi issues....when 20 other phones do not have the same issue at work....
    05-07-2014 04:53 PM
  3. AshokKusampudi's Avatar
    Same issue for me, it's not consistent
    05-07-2014 05:57 PM
  4. soniamahipal's Avatar
    I have HTC One M8 and unable to view any "Called Name ID" app. I checked for "All' apps apart from the 'Downloaded' ones but was able to locate only "City ID" app. I tried uninstalling this app but it doesn't work. Mobile data is consumed and 4G LTE icon is visible at top status bar of my mobile.
    I had a call with AT&T and they shipped me a replacement device but it is also having the same issue. I have 2 mobile devices with me and have to ship back one ASAP. Is there something we can do to fix the issue.
    07-31-2014 06:01 PM
  5. Steve K5's Avatar
    I too am new to smart phone/android, and find managing apps problematic. I am also concerned about data usage vs wi-fi. I could not find the amp called "Called Name ID". UNTIL...I found the screen called "Data Usage". There you should have a graph, and below that, apps that are using the most data. OF course "Google Store" was the main offender, but scrolling down I found app "Called Name ID". Also in this screen you can tell an app to use only WiFi. So the app does exist even though you can't see it in the main apps pages.
    I find apps hard to manage but this hidden app thing really frosts me up. Why not have a red x button with the running app screen? If you have rhapsody open, you just click the red x and it goes closes out.
    It sill looks like there is 4G activity- though I'm not entirely sure. I'm positive this uncertainty is exactly what Verizon/apps corps wants to happen. The difficulties in managing apps and data/wifi is too blatant.
    08-13-2014 08:45 AM
  6. Cuper Tino's Avatar
    Reboot the device.
    04-27-2015 12:06 PM
31 12
  1. Evo 4g LTE overheating and battery life
    By everlast316 in forum HTC EVO 4G LTE
    Last Post: 09-21-2015, 07:54 PM
  2. 4g LTE phones and ebay/craigslist
    By mylasthope in forum Verizon
    Last Post: 07-27-2012, 02:19 PM
  3. Just past a Verizon 4g lte poster and I have no 4g
    By bulvine420 in forum Verizon Galaxy Nexus
    Last Post: 07-15-2012, 10:37 PM
  4. Evo 4G LTE Problems and the Gnex
    By dmmarck in forum Verizon Galaxy Nexus
    Last Post: 05-28-2012, 05:47 PM
  5. Replies: 1
    Last Post: 09-16-2011, 08:40 AM
