1. gstewart79's Avatar
    Is there a way to have the WiFi shortcut on the notification panel? I have seen in several on-line videos that this is an option on the Galaxy S4, but my new one I just received on VzW does not have this shortcut available. If I can't add it to the notification panel, is there an app or something that will allow me to toggle?
    05-22-2013 09:32 PM
  2. Love Divine's Avatar
    LOL at Verizon if true.
    05-22-2013 11:04 PM
  3. s44's Avatar
    God, Verizon is so foul.
    I use notification toggles (including wifi) from Elixir2 on my GNex, but a whole new set of toggles would probably look silly on a S4.
    05-22-2013 11:17 PM
  4. L33tx0r's Avatar
    I don't see it either...
    05-22-2013 11:17 PM
  5. infinity12402's Avatar
    i thought they had a constant wifi type notification, not an actual toggle, but some kind of constant type thing. i dont have the phone, but i thought thats what i remember seeing on the s3 as well
    05-22-2013 11:20 PM
  6. felloffthetruck's Avatar
    This it the normal for Verizon phones. Plus the thing will bug you everytime you are within range of Wi-Fi
    05-23-2013 12:03 AM
  7. Adrian Dizon's Avatar
    nope, there isn't a shortcut to Air Gestures :[
    the t moblie S4 has them!
    Verizon please fix
    05-23-2013 12:07 AM
  8. infinity12402's Avatar
    seeing as no one knows what blocking mode is, im assuming they removed that, they also removed the air gesture toggle, and they messed with the wifi. wow
    05-23-2013 12:11 AM
  9. Joe the Insider's Avatar
    It's in the notification bar, just not near the togglee.wl works fine for me
    05-23-2013 12:23 AM
  10. DreamSTi's Avatar
    I'm not seeing it either, kind of odd they would remove that. I use BW and they have a wi-fi toggle that I have been using, works good.
    05-23-2013 09:49 AM
  1. Any way to clear recently opened apps in notification panel? Thx
    By theGman911 in forum Verizon HTC Thunderbolt
    Last Post: 01-14-2013, 09:15 PM
  2. Problem with Google Voice/Notification Panel
    By rosariorose9 in forum Verizon Droid Incredible
    Last Post: 11-12-2010, 07:51 PM
  3. Replies: 1
    Last Post: 09-02-2010, 03:25 PM
  4. Notification Panel Font Color
    By musicandnumbers in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-03-2010, 01:47 PM
  5. Notifications Panel - customize?
    By marcm in forum Verizon Droid Incredible
    Last Post: 05-01-2010, 03:05 PM
