1. dmaynard83's Avatar
    I haven't been too impressed by the battery. I have most settings on and display is on auto.
    I'm going to turn the display down as that is what looks like is draining a lot of battery.
    I usually stream Pandora at work and get around to 60 percent by lunch on my note 2.
    Let's see if low display settings will fix it.
    Sent from my SCH-I545 using Tapatalk 2
    05-24-2013 04:58 PM
  2. Coffeeman's Avatar
    Try installing Qualcomm's Battery Guru, in the App Store. Specifically designed for Snapdragon processors. This has increased my battery life by an average of 15%
    MBM7881, pbelfi and dmaynard83 like this.
    05-24-2013 05:20 PM
  3. MBM7881's Avatar
    What does it do
    Sent from my GT-N8013 using Android Central Forums
    larry313 likes this.
    05-24-2013 05:49 PM
  4. majorpayne's Avatar
    How many days have you had the phone. If i recall right it takes 3 charges to truely get optimized. to many varibles right now to tell why your battery is at 23% after almost 7 hours
    05-24-2013 05:55 PM
  5. Coffeeman's Avatar
    It monitors one's usage patterns, then will close apps based on this data. Also uses GPS to turn wifi off when not in a "home wifi" location. I like it because it is developed by the same people who make the s4's quad core processor.
    05-24-2013 06:01 PM
  6. glock813's Avatar
    The battery has definitely gotten better with time! The first day I only got about 7 hours and now I am almost 24 hours with average use! It seems like it took a couple of days to settle in...
    05-24-2013 06:03 PM
  7. LdotAdot13's Avatar
    I've been pretty happy with my battery. Over 3 hours of screen time!
    Sent from Cletus the S4 using Android Central Forums
    05-25-2013 11:17 PM
  8. SirGeorgeKillian's Avatar
    05-25-2013 11:27 PM
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 01:03 AM
  2. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 08-09-2013, 11:57 AM
  3. problems with camera and battery
    By piper09 in forum HTC Hero
    Last Post: 06-26-2013, 11:02 AM
  4. Helpful Battery Tips...
    By Darth Pooh#CB in forum HTC Hero
    Last Post: 10-29-2009, 12:12 PM
  5. Battery Length
    By wolf1989#AC in forum HTC Hero
    Last Post: 10-16-2009, 03:10 AM
