1. reelbiggecko's Avatar
    I've owned my new S4 for about a week and so far, so good, except for one issue that's really been annoying me. Every day or so, the phone simply stops registering where I am. The weather app (I've tried several) on my phone simply refuses to update. Apps like FourSquare default to my last known location, and don't seem to understand where I am. I live in the NYC area so 4G coverage is not a problem, and I've never had this issue in the past with previous devices. I've tried toggling GPS on and off, but the same issues occur either way.
    Restarting the phone seems to fix this problem every time, but it's quite annoying to have to restart my phone once a day just to get the location services acting properly. Is there something here I'm missing?
    Many thanks...
    05-30-2013 02:08 PM
  2. friedtators's Avatar
    anything you can see that might be interfering with the signal. your case is not metal is it? anything electronic interfering? the phones so new that if its a rotten gps chip it will be a few weeks before that is known for sure.
    05-30-2013 03:57 PM
  3. Scratch4's Avatar
    I had a similar issue on my Galaxy Nexus with apps and widgets not updating automatically. I found out it was a particular weather widget that was causing itself and all other widgets to stop updating. So I would try to see if it could be a paritcular app that's causing problems.
    05-30-2013 04:28 PM
  4. reelbiggecko's Avatar
    Thanks for the replies. I've noticed the issue isn't limited to weather apps or even location. If my phone is on for a while (less than a day is all it takes) without a restart, my Gmail stops pushing new emails too. I have to manually refresh it (though unlike for the weather apps, a manual refresh actually works in this case.)
    Again, as soon as I restart the phone, everything returns to normal. Does this sound like a symptom of anything I can fix, or is something physically wrong here? It's frustrating because in every other way I really love the phone.
    05-31-2013 06:51 AM
  1. Problem with Facebook Location Services on my Incredible 2 - HELP
    By cotylee1991 in forum Verizon Droid Incredible 2
    Last Post: 06-07-2015, 12:34 PM
  2. gps phone locator service
    By BaltoStar in forum Google Nexus 4
    Last Post: 03-12-2013, 07:06 AM
  3. Help With Location Services Please
    By kclewis82 in forum General Help and How To
    Last Post: 08-13-2012, 12:53 PM
  4. Help! Started phone and accounts/settings are gone
    By 6tr6tr in forum Sprint Nexus S 4G
    Last Post: 07-25-2011, 04:59 PM
  5. Phone screen very slow/Problem texting..HELP
    By crwmlw#IM in forum HTC Droid Eris
    Last Post: 06-05-2010, 10:12 AM
