1. nwwolf1's Avatar
    Some how my phone is using about 1.2 gigs RAM. Even when I have no apps open or anything. Is that correct? It seems to much.
    06-05-2013 10:34 PM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    Android uses RAM differently from a PC. Full RAM is a good thing. Apps load quicker, and the OS doesn't waste energy bringing up data it needs. Now, there is a difference between full RAM and you utilizing all of your RAM for what you want.
    I would go into Settings>Application Manager and swipe over to all apps.
    Anything that is bloatware, say Yahoo News. Click on it. You will see the Application Information screen. You will see two buttons; Force Stop and Disable/Uninstall Updates. (Uninstall Updates needs to be clicked first in order to disable). Disabling any app that you have no use for will free up more RAM for your use.
    For future reference, there is a check box below those two buttons, 'Show Notifications'. Unchecking this box will disable notifications from, for example Yahoo News, from going to your notification bar.
    06-05-2013 10:59 PM
  3. haillyl's Avatar
    Download Android System Info from the playstore, it 'll show you every single tasks running default in the background and how much ram and CPU they use.
    Sent from my LG-E975 using Tapatalk 4 Beta
    06-05-2013 11:37 PM
  4. effreyj's Avatar
    Under the "Manage Apps" menu, go to the "Running Apps" section and you'll see a breakdown by RAM.
    06-06-2013 09:43 AM
  1. Is there a way to see sites without mobile view with Chrome?
    By Ivanamanation#IM in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-13-2015, 07:46 PM
  2. Is there a way to see the Wifi password???
    By jezer29 in forum Sprint Photon
    Last Post: 05-25-2014, 05:23 PM
  3. Is there a way to see dBms on an iPhone to compare to my GNex?
    By GNex Girl in forum Verizon Galaxy Nexus
    Last Post: 02-20-2012, 09:44 AM
  4. Replies: 1
    Last Post: 06-19-2010, 04:02 PM
  5. Replies: 1
    Last Post: 02-24-2010, 05:08 AM
