08-16-2013 07:19 PM
33 12
tools
  1. Cigar-Junkie's Avatar
    I went to Verizon to get a NFC sim card and checked that it is the right one. I set up the account and received the $10.00 credit. I also setup a Chase card. With NFC on it tried it and no go. I then tried it with NFC and S-Beam on, no go. I did have the little green Isis icon in the notification area. The only other thing that I haven't tried is taking the case off. Does anybody know if the NFC will will reach through a OtterBox Commuter case? The case is not that thick and I would think it would work through it.
    I am stumped as to what is preventing it from working. Any ideas?
    06-14-2013 02:19 PM
  2. Cigar-Junkie's Avatar
    Really, 150 views and no one chimes in? This problem is driving me crazy. The only thing I can think of is because it is in test markets Verizon is blocking it here in south Carolina. I doubt it but that's all I got.
    06-15-2013 05:14 PM
  3. japetty's Avatar
    Have you tried taking the case off yet. What I have read and that is about all I know is that it will work in most places that they have the system sign for cardless pay such as ISIS and Google Wallet. I sounds to me like you have what you need to use it though. The big fuss that everyone has is they want to use the Google Wallet and they can't all carriers block Google Wallet except Sprint. Sorry I could not help you any more than that. Good Luck with getting it working.
    06-15-2013 06:57 PM
  4. The Hustleman's Avatar
    Isis is only available in 2 places so you won't get much feedback
    06-15-2013 09:29 PM
  5. kilofoxtrot's Avatar
    I am using it in Michigan with no problem.
    If you see this symbol...
    Then you are good to go.
    06-15-2013 10:29 PM
  6. Cigar-Junkie's Avatar
    http://www.bankofamerica.co.uk/lib-u...ontactless.gif
    Apparently not here in South Carolina. Curious, do you have a case on your phone?
    06-16-2013 06:15 AM
  7. kilofoxtrot's Avatar
    No.... I am using the S-View Flip Cover.
    06-16-2013 08:06 AM
  8. Cigar-Junkie's Avatar
    Thanks, I guess the next test is to take the otter box commuter cover off and try that. Still wish I could use Google wallet.
    06-16-2013 09:00 AM
  9. Jaycemiskel's Avatar
    Oh you have an otterbox on? That's probably what it is
    Sent from my SCH-I545 using Tapatalk 4 Beta
    06-16-2013 12:09 PM
  10. The Hustleman's Avatar
    Wow, yeah Google wallet does work through the Otterbox
    06-16-2013 12:38 PM
  11. majorpayne's Avatar
    I wonder if its because the Isis chip is supposedly in the Sim and less powered vs the NFC chip in the battery...
    06-16-2013 05:18 PM
  12. japetty's Avatar
    I just ordered an ISIS Sim and I will try it here in TX to see it it works. I hope it gets here about the same time the S3 32gb with CM 10.1 RC5 get here on Wednesday June 10, 2013.
    06-16-2013 05:53 PM
  13. tiger81t's Avatar
    I'd like to know as well. When I first installed the ISIS app it said that it could not read the secure element, so I swapped my Verizon SIM for an NFC SIM at my local Verizon store in Los Angeles (it says NFC on the card that you punch the SIM out of), and then ISIS installed fine, and I got the free $10 then free $15 for making my ISIS cash card reloadable. Tried using it at both McDonalds and CVS where they accept PayPal and it's doesn't work. At the CVS machine, the green LED that's normally always illuminated turned off briefly, then turned back on but nothing happened. I've used Google Wallet on my Nexus 7 perfectly fine at CVS and McDonalds in the past. I have yet to be able to use ISIS successfully and am getting pretty frustrated. I'd love to know what successful users are doing to get their ISIS to work! I have both NFC and S-Beam turned on, and do not use a case.
    06-19-2013 03:03 AM
  14. Cigar-Junkie's Avatar
    Same here but I haven't tried without the case. I really doubt they would have a NFC that could not go through an 1/8" of plastic case. Just don't feel like holding up the line with "just a second, let me try it without the case" This would be so nice to have for when I am out running without my wallet and want to buy a bottle of water, or a doughnut. MMMM Doughnuts
    06-19-2013 08:45 AM
  15. wolverine2003's Avatar
    I have been using ISIS Wallet with an Otterbox Defender case on (Georgia). For those having issues, did you touch the "Not Enabled" icon above the ISIS Cash card so it reads "Ready to Pay"? Also, I have always logged into the app before I pay. I know Google Wallet would work from the home screen and then it would prompt you for your PIN, but I haven't tried that with ISIS Wallet yet. I have noticed that the "Ready to Pay" icon shows up in the notification area once I sign in. If I exit the app, the icon goes away. If I just hit the home button, the icon stays on until the time out period (default: 3 minutes). I'm thinking the app may not work unless that icon is up there too, but I have yet to try that method so I could be wrong about it.
    06-24-2013 04:03 PM
  16. fofjjsr's Avatar
    Please be aware that ISIS isn't available everywhere yet. Up until very recently it was only in two test markets. I have had the NFC SIM since pretty much the Note 2 release, but could not use it because it was not available where I was.
    https://www.paywithisis.com/where-to-use.xhtml
    Even the ISIS site only still shows the two test markets. However it seems there are a few select locations that you can also use it. I will also confirm that my local Verizon store now has card machines that show the symbol ISIS says to look for. Still confused on this being forced on people and them not even allowing Google Wallet. Because I can't use my bank card with ISIS, and the only Credit Card I have that would work is my Business Credit Card, which I refuse to use with ISIS atm.
    06-26-2013 01:13 AM
  17. Zacharyaln08's Avatar
    I recently purchased the Droid Razr M. Like 2 weeks ago and it has a 4G Sim. I'm wondering if the Isis sim cards say anything to differentiate them from a normal 4G sim card? I only ask because mine does not, and I was able to set up an Isis account here in Jackson, Michigan without any problems. Haven't had a chance to test it yet, because I thought it wouldn't work yet unless I lived in one of the two test areas.
    But according to you, you are already using it in Michigan, Can i ask where you live? I'm Gonna try it this week somewhere and find out if it works. Thanks in advance.
    07-16-2013 12:13 AM
  18. mnfats127's Avatar
    Used ISIS in HI with an Verizon S4 at Mcdonalds. No case. No issue.
    07-16-2013 01:34 AM
  19. Zacharyaln08's Avatar
    Update**
    Used Isis today at a PayPass and it was successful. In Michigan on Droid Razr M
    07-19-2013 06:28 PM
  20. Cigar-Junkie's Avatar
    Decided to give it another shot in Raleigh at a vending machine. Pulled up Isis and it needed several updates. After the updates it worked like a charm.
    07-20-2013 10:02 AM
  21. PhobicCarrot's Avatar
    Where in Raleigh was this vending machine? Have you tried it in other places in the Triangle?
    07-22-2013 05:47 PM
  22. Cigar-Junkie's Avatar
    Marriott coke vending machine on the tenth floor. Was there for the weekend so that was the only attempt. Tried at a McDonalds in south Carolina but the line was long and when I moved the phone to the pad my finger hit a button. That screwed up the transaction and I didn't have the nerve to retry. I'll report my next attempt.
    07-27-2013 05:24 AM
  23. AndroidJay's Avatar
    WOW, Isis has horrible reviews in the app store. Doesn't sound worth even trying it.
    07-27-2013 06:18 PM
  24. Cigar-Junkie's Avatar
    If your on Verizon you don't have much of a choice. I would much prefer Google wallet but Verizon blocks it.
    Jaycemiskel likes this.
    07-28-2013 07:09 AM
  25. Jaycemiskel's Avatar
    They block it but I still found a way to use it. I'll try isis when they let people with rooted phones use it.
    07-28-2013 11:09 AM
33 12
  1. Anyone able to get My Backup Pro working?
    By MRW1215 in forum Amazon Kindle Fire
    Last Post: 12-09-2011, 05:28 PM
  2. Replies: 0
    Last Post: 11-06-2011, 06:04 PM
  3. Replies: 1
    Last Post: 10-19-2010, 05:18 PM
  4. Cant seem to get this email to work!
    By AQucsaiJr in forum Motorola Droid
    Last Post: 07-27-2010, 09:30 AM
  5. How to get wifi tether to work
    By alex5252 in forum HTC Droid Eris Rooting, ROMs, and Hacking
    Last Post: 04-18-2010, 08:54 PM
