03-03-2015 02:26 PM
36 12
tools
  1. jathtech's Avatar
    My issue was from blocking mode. I wanted it set up from midnight to 7 blocking only the text notification sounds, but it was accidentally set from noon to 7am, so it was only making the sounds for 5 hours a day when I don't actually use text anyway. Change your blocking mode settings and see if that works.
    Matthew Henry1 likes this.
    03-16-2014 02:52 AM
  2. Greg22's Avatar
    I get no sound when I get a message. Set on whistle and vibrate, get neither one. Help. GS4
    Went to messages-setting- then read through them and found out I had a box check that canceled out the sound for receiving notifications. Hope this is some help. If not sorry.
    03-24-2014 10:17 PM
  3. Scott Ryan2's Avatar
    Hi i had same prolbem i did factory reset it worked for a day and lost sound again i worked it out to be (Hangouts) i stop using it and my message tone came to life lolz
    04-02-2014 02:24 AM
  4. ElmiPrime's Avatar
    04-21-2014 01:07 AM
  5. ElmiPrime's Avatar
    Pull up ur notification bar at bottom right den u will c wifi, gps, sound, screen rotation, power saving den u swipe
    2 left and u will see more options & u'll also c notifications icon then press dat 2 turn it on & green and start receiving
    notification again
    04-21-2014 01:10 AM
  6. Jbankscomm's Avatar
    I have a Galaxy S4 and just solved this issue:
    Tap the system access button to the left of the main home physical button, then:
    Go to System Settings > My Phone > Sound > Volume
    Make sure the Ringtone volume is not zero, then you can adjust the Notifications volume. In my case the Notifications volume had been turned down to nothing:
    Verizon Galaxy S4: No Message notification sound-notificationsvolume.jpg
    Note that you can only adjust the Notifications volume if the Ringtone volume is greater than zero.
    Thanks
    Attached Thumbnails Verizon Galaxy S4: No Message notification sound-screenshot_2014-08-14-11-01-00.jpg
    08-14-2014 02:21 PM
  7. Jbankscomm's Avatar
    A follow-up to my own post:
    There is a shortcut to the notifications volume:
    On your home screen, adjust the volume up using the buttons on the side of the phone. Notice the gearwheel icon:
    Verizon Galaxy S4: No Message notification sound-volumeshortcut1.jpg
    Tap that and you have quick access to all the volume levels:
    Verizon Galaxy S4: No Message notification sound-screenshot_2014-08-14-13-00-05.jpg
    Thanks
    08-14-2014 04:10 PM
  8. Ken Griffith's Avatar
    Was having same problems.. compared all my hangout settings with a friend's (that is working on same phone).. all checked out. I went into Settings -> More -> Application manager to uninstall and try re-installing.. when I noticed the [ ] Show notifications was not checked.. I check-marked it.. and started working just fine.
    BeverlyF likes this.
    09-25-2014 11:31 AM
  9. Lucian Govender's Avatar
    my phone keeps on whistling but when i check if i have any messages theres nothing there...pls look into it thx lucian govender 0728516842
    12-17-2014 01:38 PM
  10. Dale Vornholt's Avatar
    Had the same problem. Here's the fix I found: Push the volume either up or down, (doesn't matter) and you will see a settings wheel all the way on the right. Tap that, and a menu comes up, and "notifications" is one of the things displayed. Make sure that the "volume" adjustment is set so that it is all the way over to the right, which means that the "volume" for the sound for the text messages is on "high." Worked for me. Emailed Chomp and 3 suggestions as to what to do, and none of these worked because the issue was not an app issue; it was a phone issue.
    01-06-2015 12:05 AM
  11. Matthew Henry1's Avatar
    You're a star! That was my problem.
    03-03-2015 02:26 PM
36 12
  1. Replies: 11
    Last Post: 04-07-2013, 04:11 PM
  2. How to extend or repeat a sms or text message notification sound
    By Mel Vine in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-21-2013, 08:35 AM
  3. Message Notification Sound cant silence?
    By Rammsteinfan in forum T-Mobile Galaxy S Blaze 4G
    Last Post: 07-24-2012, 05:12 PM
  4. Text Message Notification Sound?
    By yenrab26 in forum AT&T Galaxy S II
    Last Post: 01-11-2012, 04:47 PM
  5. Is there a notification sound for missed messages?
    By nneptune in forum Verizon Droid Incredible
    Last Post: 07-23-2010, 02:47 PM
