1. jimbl's Avatar
    I see a lot of listings on eBay for "factory unlocked" S4's and generally they claim they work on carries with a correct SIM card for that network. My understanding though is they may "work", but may not support all bands / frequencies. Meaning technically it will "work", but may not work on 4G, or work for voice, etc. So is there such a device that is Unlocked that will work completely on Verizon that isn't made for Verizon's network? Thanks.
    07-22-2013 02:42 PM
  2. paintdrinkingpete's Avatar
    Someone can correct me if I'm wrong, but I don't think any "unlocked" phone will work on Verizon regardless of what bands it supports. I'm pretty sure you need a Verizon version if you want to use it on their network, primarily because their CDMA network is completely locked down to outside phones.
    EDIT: The caveat to that is, however, that you can use Verizon phones on *some* other networks.
    jimbl likes this.
    07-22-2013 02:55 PM
  3. jimbl's Avatar
    Thank you, and that does sound right to me. That's how I've always thought it's been. It's frustrating to see sellers "false advertise". Many list the "32GB S4" with no mention of any SD card. When I contact them for confirmation they reply "16GB with 16GB SD Card". Thanks again.
    07-22-2013 03:00 PM
  1. Samsung Galaxy S3 Water Damage Help
    By browning1 in forum Samsung Galaxy S3
    Last Post: 05-11-2014, 09:15 AM
  2. $15 amazon gift code to whoever can help me root the ematic genesis prime
    By TapZoo Cheats in forum General Help and How To
    Last Post: 08-14-2013, 07:15 AM
  3. Does Android just have the inferior versions?
    By UltiDroid in forum General News & Discussion
    Last Post: 07-26-2013, 05:08 PM
  4. HELP. New update issue!
    By ylab in forum Droid RAZR MAXX HD
    Last Post: 07-24-2013, 06:38 PM
  5. S4--SMS Notifications Don't Work--Help!
    By Seth_Overbury in forum Samsung Galaxy S4
    Last Post: 07-24-2013, 03:23 PM
