1. rickbagby's Avatar
    I updated to the new 4.2.2 last week and ever since my S4 battery has drained extremely fast. I have added no new apps. The only two items the battery meter shows is the Android OS (94%) and the Screen. I have had a very light day on the phone today and I am at 17% battery life. Before the upgrade I would have been in the 70% range. Is this caused by the new update?
    07-22-2013 08:28 PM
  2. General Tso's Avatar
    Same here. I haven't found an answer yet. I have a weak 4G signal so I think that's part of it.
    Sent from my SCH-I545 using Tapatalk 2
    07-22-2013 09:50 PM
  3. anonymous495876038576's Avatar
    Is there a way for you to disable the 4g radio in the settings? Unless you happen to need 4g. If its not in the settings then I recommend looking for an app in the app store
    Sent from my XT881 using AC Forums mobile app
    07-22-2013 10:25 PM
  4. Tahoe916's Avatar
    I don't know if this will help but something I've been looking at lately myself when tweaking battery use. Try https://play.google.com/store/apps/d...detector&hl=en, turn on advanced mode in the settings and then tap on Android System in both Screenlock wakelock and CPU wakelock to get a detailed breakout. My battery usage hasn't had a problem with this process, my biggest one is Google services but overall good battery life. Right now at 65% battery after 11.5 hours with 58 min screen time.
    07-22-2013 10:28 PM
  5. General Tso's Avatar
    No. Verizon won't let you.
    07-22-2013 11:49 PM
  6. anonymous495876038576's Avatar
    I personally find that stupid as its your phone but I guess that's what you have to deal with if your on Verizon. When I was on Verizon with the droid bionic I was able to turn off 4g in the settings
    07-23-2013 12:09 AM
  7. General Tso's Avatar
    Yep. My old Thunderbolt I could also. I think even SG3 could. You could go into the network settings and pick. Now the only option is Global or LTE/CDMA.
    07-23-2013 12:50 AM
  8. General Tso's Avatar
    Attached Thumbnails Galaxy S4 Battery Drain-uploadfromtaptalk1374555099165.jpg
    07-23-2013 12:51 AM
  9. tytlyf's Avatar
    download the Wakelock Detector app and let your phone run on battery a couple hours before opening it. That will tell you vital info about what is keeping your phone awake.
    Hikmat abdoollayev likes this.
    07-23-2013 10:39 AM
  10. garublador's Avatar
    I had an app go rogue right after I got the update, too. Along with Wakelock Detector, I recommend GSam Battery Monitor. It will give you much better information about what's using your battery. Doing a factory reset after getting the update is a good idea, too.
    adaptx likes this.
    07-23-2013 12:50 PM
  11. sandra211's Avatar
    If it doesn't matter if you take some time to figure out the overall issues, I highly recommend "Carat"- it's a project of computer science dept.(mostly post Masters') at Berkeley. With a quick opening of the app, which uses nearly no energy & does not run in background, it checks whatever is a major draw on the batter, makes recommendations re what to kill, get rid of, etc. & tells what minutes will likely be gained by each action.
    They suggest opening the app each day when it takes a snapshot of the system. Over about 30 of those snapshots, (my experience with 1st phone-it took shorter time period than 30). it gives J-score which tells how you stack up compared with others of same phones. With RAZR, I started wit J-score of 27, I ended up with 72 after following their suggestions. Their support is amazing & the people responding have impressive education & get it! I've given just a snapshot & it does much more than described here. Forums are found in back after seeing the categories of apps that have bugs, are HOGS, or other issues- Forums are extensive but could be overlooked if last section is not scrutinized & scrolled to locate. Please give this a try! I have no connection other than user with Carat.
    adaptx likes this.
    08-19-2013 03:24 AM
  1. [Guide] Battery Saving Tips
    By B. Diddy in forum Ambassador Guides, Tips & How-To's
    Last Post: 03-06-2015, 12:33 PM
  2. Galaxy s1 back camera can't take pictures
    By Ali Husain in forum General Help and How To
    Last Post: 08-11-2013, 08:26 PM
  3. Finally upgraded from the HTC Rezound to the S4 32GB
    By AndroidJay in forum Verizon Samsung Galaxy S4
    Last Post: 08-10-2013, 09:36 AM
  4. AT&T Samsung Galaxy S4 Text Messaging Issues causing Slowness
    By Gregory Teng in forum AT&T Samsung Galaxy S4
    Last Post: 07-22-2013, 11:58 PM
  5. S4 Firmware Update Prompt - Should I Download It?
    By BobR1908 in forum Samsung Galaxy S4
    Last Post: 07-22-2013, 10:13 PM
