1. jadenoir7's Avatar
    I have this case and when I inserted the phone in the case it did not work I get no mobile network. Is there something wrong with this case or my phone just wondering if anyone else experienced this with this case.
    08-05-2013 10:35 PM
  2. B. Diddy's Avatar
    Wow, bling!! I wonder if the metal in the case could be interfering somehow.
    Scott Kenyon likes this.
    08-05-2013 10:44 PM
  3. AndroidJay's Avatar
    Never tried that case. I can say that the Otterbox Defender case works perfectly. I have not had one problem yet. What is the name of that case you have pictured?
    08-06-2013 09:01 AM
  4. MBM7881's Avatar
    I had something similar on my S3 except it was a battery back cover and it dramatically reduced the network signal. My S3 kept saying network error and such
    Sent from my GT-N8013 using AC Forums mobile app
    B. Diddy likes this.
    08-06-2013 10:01 PM
  5. T Android's Avatar
    It may be caused due to the fact that the case blocks the signal and the signal was weak in the first place. I know someone that has a very similar case and they didn't have any problems with the signal. The phone was on T-Mobile and it was an S3.
    08-07-2013 01:29 PM
  6. MBM7881's Avatar
    That could be true. I was on sprint. Now I'm with Verizon
    08-07-2013 01:48 PM
  7. Raptor007's Avatar
    What is the case made of? If its metal then that is likely the issue. It could also be a signal issue in the area you are using it at, but if you take it out of the case and the signal jumps then the case is a no go, bling or no bling. Nice case though
    08-09-2013 11:10 PM
  1. Replies: 5
    Last Post: 08-08-2013, 05:04 PM
  2. Phone dying
    By sjpld23 in forum Verizon Galaxy S III
    Last Post: 08-06-2013, 02:26 AM
  3. Updating using an unlocked phone
    By hurricanekick360 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 08-05-2013, 10:16 PM
  4. Xbox 360 X-Stripe Case Mod
    By gollum18 in forum The Gamer's Lounge
    Last Post: 08-05-2013, 10:01 PM
  5. Replies: 0
    Last Post: 08-05-2013, 09:57 PM
