I am about to order the 32 GB GS4 on Verizon next week. I've been reading much about the VRUAME7 update, and the possible need to do a hard reset after the update to see the Wifi toggle etc. My questions are :
(1) For anyone who has ordered and received the 32 GB version recently, did it arrive with the VRUAME7 software, or did you have to do an update?
(2) If you did have to update, was the update available immediately, or soon after activating? If so, how soon?
(3) Is Keis available for use with the Verizon GS4?
I ask because I definitely want the WiFi toggle there. If a reset is needed after getting to ME7, I don't want to spend a bunch of initial time setting the GS4 up, only to have to do it again. My plan is to not set anything up after activating, until I am on ME7. I just want to make sure I can get to ME7 soon after activating .
Thanks in advance for your help.
Don
Don
