SD card problem
jbomb11
Banned
Mar 22, 2010
606
13
Have a 32gb card put it in my s4 and it won't mount. Tried to reformat it upon inserting it and it just keeps saying it is blank or has unsupported files...
Any ideas? Thanks in advance.
Sent from my SCH-I545 using Tapatalk 2
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,281
4,390
113
Is there important data on the SD? If not, try formatting it on your computer (using FAT32). You might want to do the full format, rather than the quick format, in case there are any bad sectors.
fatboy97
4,820
891
Any possible directions on how to do that?
Thanks
You can buy a USB adapter key that will plug into your USB port on your computer... it will show up as a new drive... then just format the card as stated above using FAT32 format type.
cyari6908
