1. jaybro0813's Avatar
    Sent from my SCH-I545 using AC Forums mobile app
    08-24-2013 05:15 PM
  2. Greg C's Avatar
    08-24-2013 05:39 PM
  3. fatboy97's Avatar
    I guess my first question would be, what apps are you using right now? Next is which of those apps do you absolutely need to be using?
    Personally I pull mine from my charger every workday morning at 5:30am, and have at least 50% battery life when I plug it in at 10pm.
    08-24-2013 06:35 PM
  4. jaybro0813's Avatar
    Is your Internet on all day?
    08-24-2013 07:33 PM
  5. fatboy97's Avatar
    I guess you're asking me, and the the answer is yes... LTE, with the help of WiFi at home and at work. This also includes going to the gym and playing music for an hours or so, plus some games late in the evening.
    Now are you going to answer my questions above?
    08-24-2013 08:27 PM
  6. jaybro0813's Avatar
    I use instagram and Facebook primarily. A little bit of Scorecenter. In addition, I seem to be using my data plan pretty rapidly. What do you recommend? I am frustrated
    08-24-2013 09:54 PM
  7. cyberchief's Avatar
    Hyperion extended battery and Seido extended battery case (fits over the Hyperion). I get more than a day and a half with moderate to heavy use.
    08-25-2013 10:54 AM
  8. fatboy97's Avatar
    All of those are definitely going to use data... anything with a lot of images will probably use up more data than others. You can always go under Settings > Connections tab > Data usage and scroll down through the list to see what is using up your data. You can also go under Settings > More tab > Battery to see what is using up your battery.
    Do you have any access to Wifi anywhere? I'd definitely suggest you find some and use it when you can. If not, you are going to burn up your data fairly quickly. Wifi will also save your battery even if you are in a good LTE area.
    08-25-2013 12:02 PM
  1. Moto X Battery Life
    By whtchdr in forum Moto X (2013)
    Last Post: 08-23-2014, 09:53 AM
  2. How to change S Planner to Month View on Home Screen?
    By adds416 in forum Samsung Galaxy S4 Google Edition
    Last Post: 02-05-2014, 11:36 AM
  3. Use Google Account for Play Store Only?
    By tlehmann in forum General Help and How To
    Last Post: 10-29-2013, 01:54 PM
  4. What happened to my Google Music Player - it turns on by itself when charging
    By gemniii in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-24-2013, 09:33 PM
  5. Transfer Files from internal storage without turning phone on
    By Sabrina Rose in forum Sprint Motorola Photon Q
    Last Post: 08-24-2013, 05:14 PM
