1. greycobalt's Avatar
    I've been using my S4 a week and a half, and I've loved it, and been pleasantly surprised with it's battery life. However, yesterday and today the life took a sharp turn for the worse, and drained to half battery without any use by the middle of the day. I use GSAM, but the logs are gibberish to me, so I was wondering if anyone here could tell me what's going on. Yesterday, the Android OS Kernel was the main culprit, today the Bluetooth Share is.
    I was going to post them as plain text, but they're pretty long, so I'll attach them. If someone wants me to post them plainly, let me know. Thanks in advance for your help!
    08-29-2013 02:01 PM
  2. garublador's Avatar
    I haven't gone through the logs, but did you have to do an OTA update after you got the phone? I had an app go rogue after the OTA update (ironically it was Battery Guru) and I was missing the WiFi toggle (which was added in the update) so I did a factory reset. That solved all of the problems.
    08-29-2013 02:15 PM
  3. greycobalt's Avatar
    I didn't do any OTA update after I received it, at least not to my knowledge. Do they download/install automatically? If not, then no, I did not.
    08-29-2013 02:42 PM
  4. skyjjc's Avatar
    I had a similar issue. The Gsam app sucker showed that an app was initiating wake lock for audio in/out. Gsam provided the app UID but I couldn't find the correlation from the app UID to a particular app.
    Anyway a standard reboot (not factory reset) fixed the problem for me.
    08-29-2013 04:31 PM
  5. gadgetmom88's Avatar
    I had to turn off Google location Services to fix mine. Was a gps drain. I'm hoping to find another fix so I can confine l continue to use Google Now...
    Sent from my SCH-I545 using Tapatalk 4
    08-30-2013 09:14 AM
  1. My s4 battery drains too fast
    By omar ghonimat in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-26-2015, 05:26 PM
  2. Battery life is terrible on my Galaxy S3! Need help ASAP!
    By luqman24 in forum Samsung Galaxy S3
    Last Post: 07-31-2014, 10:46 PM
  3. Replies: 16
    Last Post: 09-17-2013, 01:41 PM
  4. Galaxy S3 battery woes
    By davids3user in forum AT&T Galaxy S III
    Last Post: 08-30-2013, 08:23 AM
  5. Several "how do I" questions
    By byitb in forum Motorola Droid MAXX
    Last Post: 08-29-2013, 12:14 AM
