1. Murph5150's Avatar
    I spoke with Verizon and they don't offer one but they offer a case which supposedly is supposed to charge your phone on the fly. Has anyone used it? And can anyone point me in the direction of where to find a good time quality extended life battery? Thanks!
    Sent from my SCH-I545 using AC Forums mobile app
    09-03-2013 10:33 AM
  2. Scott Kenyon's Avatar
    The case they offer is probably the Mophie Juicepack, which is a quality battery case. Anything by Anker is usually pretty good as well as Zerolemon.
    09-03-2013 10:47 AM
  3. Murph5150's Avatar
    How does the Mophie Juice Pack work?
    09-03-2013 12:35 PM
  4. Scott Kenyon's Avatar
    It plugs into the microusb, and also has an external microusb to charge it. It also has an on/off button. This case does add significant bulk to your device.
    09-03-2013 02:53 PM
  5. tippmann15's Avatar
    Seidio extended batteries have always been my go to batteries.
    GS4/iPhone5
    Scott Kenyon likes this.
    09-03-2013 03:16 PM
  6. Scott Kenyon's Avatar
    They're good as well. If you're afraid of the third party ones, you can always get the OEM extended batteries.
    09-03-2013 03:49 PM
  1. Screen permanently dim after battery died!
    By moodyk13 in forum HTC Vivid
    Last Post: 09-11-2013, 03:23 AM
  2. Poor signal quality.
    By jc0187 in forum Samsung Galaxy S4
    Last Post: 09-08-2013, 06:21 PM
  3. New Nexus 7 Battery/Heat Problems
    By Winterswind in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-04-2013, 07:20 AM
  4. N4 battery dies overnight
    By Planins in forum Google Nexus 4
    Last Post: 09-03-2013, 10:23 AM
  5. Deep sleep battery saver.
    By kanesmith41 in forum Sprint Galaxy Note 2
    Last Post: 09-03-2013, 09:48 AM
