1. 44pirate's Avatar
    What is it and do I need it.
    09-07-2013 01:30 PM
  2. jpriest007's Avatar
    Can you post a screen shot of it?
    09-07-2013 02:25 PM
  3. fatboy97's Avatar
    Screen Shot = get it on the screen you want to take a shot of... Press both the Power button and the Home button at the bottom of the screen at the same time.
    09-07-2013 05:58 PM
  4. msndrstood's Avatar
    Did you update Facebook? There is now a greyed out globe in the notification bar and a shortcut in the pull down shade.
    Sent via Note II
    09-07-2013 06:09 PM
  5. 44pirate's Avatar
    The second screen shot is what I'm talking about. Can I remove it?
    09-07-2013 07:10 PM
  6. msndrstood's Avatar
    Yes, in the pull down shade click on the x all the way to the right (past the third arrow in the picture) it takes you to the FB notification center. Uncheck the box, the globe goes away.
    Sent via Note II
    09-07-2013 07:36 PM
  7. msndrstood's Avatar
    Fourth arrow shows where the x is.
    Sent via Note II
    09-07-2013 07:57 PM
  8. 44pirate's Avatar
    http://img.tapatalk.com/d/13/09/08/u7uqy6yr.jpg
    Sent via Note II
    thank u
    09-07-2013 08:21 PM
  9. msndrstood's Avatar
    No problem. I just updated FB and saw it right about the same time you posted, so I figured it out for the both of us.
    Sent via Note II
    09-07-2013 08:42 PM
  10. Karin Witteveen's Avatar
    Hallo,
    Is there an option to pull it back on? I have accidentally pushed the x and deleted it !!
    12-11-2013 09:15 AM
  1. Replies: 11
    Last Post: 11-24-2015, 09:05 PM
  2. ASUS MeMO Pad 8 hands on & Specs
    By srkmagnus in forum ASUS MeMO Pad 8
    Last Post: 10-07-2014, 03:55 PM
  3. LG G Pad 8.3 Hands-On
    By srkmagnus in forum LG G Pad 8.3
    Last Post: 12-11-2013, 03:13 PM
  4. P5113 problem with usb connection in windows.
    By guitarplayer06 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 11-14-2013, 09:20 PM
  5. Replies: 2
    Last Post: 09-07-2013, 12:03 PM
