1. Lwapo's Avatar
    Hello,
    I was helping a friend free up some space on his Galaxy S4.
    We put a Mini SD card in and moved his pictures to it. We went into the settings, then to storage and selected the gallery. When pressing down on it, it gave us a "Move" option. Once selected, that let us move all of the images to the SD card.
    Now the images show as being there (there is a generic icon for each image) but they will not display on the phone.
    I tried popping the SD card into the computer to view them as well but that did not help either.
    Can anyone give me any ideas on what I could do?
    Thanks!
    10-03-2013 01:00 PM
  2. STSVA's Avatar
    Hello,
    Thanks!
    Have you checked to see if they're also still on the phone's internal memory storage? If they are, I'd suggest copying (not moving) them by USB to a computer, and only after confirming that they're on the computer deleting them from the phone's internal storage.
    10-03-2013 02:46 PM
  3. paintdrinkingpete's Avatar
    Yeah, sounds like files may have been corrupted in transfer? This is why you should always *copy* files from source to destination instead of move, that way you can verify the files were transferred successfully before deleting the originals.
    May be time to restore from a backup...at the very least hopefully your friend uses the auto-upload features of Dropbox or Google Drive.
    10-04-2013 11:47 AM
  1. Activate camera with power button?
    By konen_knife in forum HTC One M7
    Last Post: 12-14-2015, 04:45 AM
  2. Maxx having issues with maintaining data on WiFi
    By GuyWith4Kids in forum Motorola Droid MAXX
    Last Post: 07-08-2014, 08:21 PM
  3. Galaxy S4 recieve duplicate pictures
    By Jowiii3 in forum AT&T Samsung Galaxy S4
    Last Post: 11-08-2013, 02:00 PM
  4. Can I use unlocked S4 with Sprint?
    By InfoSeek in forum Sprint Samsung Galaxy S4
    Last Post: 10-07-2013, 08:59 PM
  5. New to android Help
    By riki26 in forum Google Nexus 4
    Last Post: 10-03-2013, 06:36 PM
