Re: WiFi issues on 4.3
I've tried everything from updating my router, to changing router settings, to changing wifi settings on my phone. Short of doing a factory reset, I'm out of ideas. Nothing seems to work (although changing my router settings seemed to fix it for like a week, but perhaps that was just an anomaly and coincidental).
Anyway, here's the issue I have, that I seem to share with many people:
1 )The Wi-Fi will say its connected, but it won't work. Even though it says its connected, I cannot update news feeds or surf the web or do anything needing the internet. Usually I just wait for around 20 or 30 seconds and it will reconnect saying "Connected to Wi-FI network ______" and then it works fine for another 10 minutes before doing it again.
2) When I unlock my phone/wake it up, it sometimes says the "Connected to Wi-Fi network ______".
It is extremely frustrating, because I use Google Now voice commands for a lot of things, and none of them work when this happens. It's also slightly embarrassing to be showing off my phone, and ask google now to do a fancy command, only to have it sit there for a while doing nothing while it tries to load.
It did this when it had Android 4.2.2 as well, although not as frequently as 4.3 (unless I'm just noticing it more). I'm almost to the point where I'm going to disable wifi all the time and just use LTE
Here's a screen shot of the Google Now annoyance:
