1. rosemore's Avatar
    I have a Verizon S4 which was just updated to 4.3.
    There has been a continuing problem even before the update with the Blue Buds X dropping the bluetooth connection on a random basis. Sometimes it is every few minutes or even once per hour.A replacement Blue Buds has the same problem. All other Bluetooth connections with my S4 to my car, and a Creative BT speaker are fine.
    Re-pairing didn't help either.
    Could there be a setting in the phone that could cause this behavior?
    Thanks for any advice!
    11-03-2013 08:24 PM
  2. Steve LeMire's Avatar
    I'm having the same problem....I think it's the phone!
    02-20-2014 02:12 PM
  3. Scott McCauley's Avatar
    Have the same problem with my S3 and Bluebuds. S3 works great with many other bluetooth headsets. It seems to be only the Bluebuds. Exact same symptoms that you describe.
    05-21-2014 07:13 AM
  1. Replies: 10
    Last Post: 05-29-2015, 05:24 PM
  2. FLASH problem for TAB 3 8.0 4.3.3
    By Nychotxxx in forum Samsung Galaxy Tab 3
    Last Post: 05-05-2014, 10:20 PM
  3. Trusted Blue tooth device like vybe>
    By zobog in forum Moto X
    Last Post: 11-04-2013, 11:11 AM
  4. Bluetooth issuse with note 3
    By nicholasyoung in forum Samsung Galaxy Note 3
    Last Post: 11-04-2013, 08:44 AM
  5. Need help making email work.
    By James Cooper 1 in forum General Help and How To
    Last Post: 11-03-2013, 01:58 PM
