Re: Whenever I click on Phone icon I get "Unfortunately, contacts has stopped"
Resetting the clock worked for me... my replys are not in order. This was my exact issue. I did the full on reset to factory and reload with Verizon and the issue returned the next day. It started after an update a long time ago and I waited to get it fixed. It was annoying, but I dealt with it by putting numbers I needed to call into contacts. I finally called them way back in November and, after an hour, they wanted to reset the phone but I wanted to transfer stuff onto the computer first, which I procrastinated on. Well, I had a huge wake up call when I was trying to get my daughter, who has severe seizure disorder, to the ER and I could not call 9-1-1! Apparently, you can't put 9-1-1 into your contacts! A nightmare. That prompted me to get off the ball and call Verizon. It took over an hour to trouble shoot and reset the phone, only to have the issue right back the next day. This time I called right away and, while I was on the phone with the Tech, I googled the problem and found this forum. I read the clock issue fix to the tech and then I did it. IT WORKED!! I told her to put it in whatever trouble shooting algorithm they use because I'm not the only one with this problem. Samsung should know about it, too! My brother in law and son have the same phone (and they have had it longer) so it's a mystery why only certain phones are affected. Still working today, too. Also, many of my Samsung apps that came with the phone, like "story album" and S memo and many others never worked. I would, for example, write a memo and click save and it would say "unfortunately S memo has stopped".... Guess what? They all work now and some of them are pretty cool! I got my phone back in July and had actually removed the non working apps and widgets because they did not work. When I reset the phone, they all came back onto the phone and they were not working until I reset the clock. This is so great because I really like the phone!!! Many MANY thanks and I'm so glad I used the search term "unfortunately contacts has stopped" with google to find you!
