1. Gobbling_Monkey's Avatar
    Hello. I have a Verizon Samsung Galaxy S4. It is running android 4.3. I have this occasional problem where when I take a picture with my galaxy S4, the picture will just be lines. I will include a picture to let you know what I mean by that. My phone is rooted, however, this problem has happened before it was rooted, so that is not the problem. This does not happen all the time. What can I do to fix it? Thank you.
    11-28-2013 04:08 AM
  2. STSVA's Avatar
    It's pretty clearly data corruption. Are you saving the image files to internal storage or an external sd card?
    Sent from my SCH-I545 using AC Forums mobile app
    11-28-2013 06:56 PM
  3. Gobbling_Monkey's Avatar
    I am saving to an external sd card. Also, it is weird when you click on the photo and there is a preview thing on the bottom of the screen, the picture looks fine. It only looks like this when it is big. How can I prevent this? Should I start saving to my internal memory instead or even get a new sd card? Thank you.
    11-30-2013 01:05 AM
  4. mrsmumbles's Avatar
    Test the pictures on the card in another device if possible.
    I had pictures on a card that looked similar, but very "blocky" like a bad cable TV picture, and I thought the card got corrupted. But when I put the card in a different phone the pictures were all fine.
    Sent from my Nexus 5 using Tapatalk 2
    11-30-2013 02:00 AM
  5. lmandl's Avatar
    Is it a SanDisk card? There is a known issue between Samsung and sandisk. SanDisk does warranty their cards for life. Call them and they'll send a call tag for the old card and replace it with a new one with up to date software.
    12-06-2013 07:59 PM
  6. Gobbling_Monkey's Avatar
    No. It is not. It is a kingston.
    12-12-2013 12:00 PM
  1. Nexus 7: Having issues with folder transparency after 4.4 update.
    By wolverine2003 in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-10-2014, 09:02 AM
  2. Touchless Control - Play Music Problem
    By Boomax24 in forum Moto X
    Last Post: 05-24-2014, 06:19 PM
  3. LG G2: cannot connect to camera
    By depechemodegurl in forum LG G2
    Last Post: 01-22-2014, 09:05 PM
  4. Replies: 4
    Last Post: 12-04-2013, 03:26 PM
  5. Lost all my pictures on my camera roll
    By RealEstateCop1 in forum AT&T Samsung Galaxy S4
    Last Post: 11-30-2013, 01:47 AM
