1. stefanib123's Avatar
    I just got the Samsung Galaxy S4 2 days ago. On my data usage screen, it says an app called "Remove Apps" has used almist 700 mb in that time! It wont let me disable it from there, and when I go to App manager, I cant find it! Can someone help? I have a screenshot, let me figure out how to post it.
    Maren86 likes this.
    12-01-2013 02:14 PM
  2. stefanib123's Avatar
    12-01-2013 02:20 PM
  3. kernmal's Avatar
    When you uninstall an app that has used data, the amount of data that it used gets lumped into Removed Apps. The amount is cumulative.
    If you had two apps that each used 50MB of data you would normally see both apps listed. If you uninstalled both apps, they would disappear from the data usage listing and you would have a new listing for Removed Apps showing 100MB.
    Did you try out and uninstall any games?
    12-01-2013 02:24 PM
  4. stefanib123's Avatar
    I did. And I uninstalled a bunch of crappy apps that came on my phone from my locsl provider. Ive not seen it today, so hopefully I wont see it again?
    Thanks!
    Sent from my SCH-I545L using Tapatalk
    12-01-2013 09:18 PM
  5. kfres39389's Avatar
    Use ES file explorer and manually go through your internal SD card. Delete everything you can; or even copy and paste everything that isn't tied directly to the system onto your computer. Pictures, old APKs, video, backups, .zips(those take up a huge amount of space), music, etc. Also look into SD card cleaners as well as App 2 SD. Use ROM Toolbox's app manager to delete unneeded system apps.
    01-12-2014 09:34 PM
  6. Laurabean113's Avatar
    Which system apps do you recommend uninstalling?
    04-23-2016 03:23 PM
  7. bugz64's Avatar
    That really does not seem fair .I use data when I play a game. That is part of my monthly data then when I uninstall the game they take away the data a second time. Data that they had already put toward my monthly alotment. I am going to try turning off my data from now on when I uninstall any and all apps and games .
    11-07-2016 01:14 AM
  1. [NEW][APP] Screen Stream Mirroring
    By Facemarks in forum Android Apps
    Last Post: 07-28-2014, 06:00 AM
  2. Samsung Galaxy S4 HELP 4.4 update
    By poli881990 in forum Samsung Galaxy S4 Google Edition
    Last Post: 12-01-2013, 07:07 PM
  3. Recent apps after pushing home button
    By mugsaway in forum Samsung Galaxy S4
    Last Post: 12-01-2013, 03:35 PM
  4. Samsung Galaxy S3 Mini mini setting up a pop3 email account
    By elmesy in forum Samsung Galaxy S3 Mini
    Last Post: 12-01-2013, 01:32 PM
  5. G2 eye tracking is impressive
    By heading4tomorrow in forum LG G2
    Last Post: 12-01-2013, 01:22 PM
