1. 1800getownd's Avatar
    So I recently got a GS4 and I'm having WiFi issues. WiFi worked for a day then I started getting "Your network connection is unstable" and wifi no longer worked. Researched this problem a bit and 4.3 seems to be the cause of it. I think it may be an app that kicks in that causes WiFi to fall off.
    I tryed:
    - restarting router
    - fooling with router settings
    - disabling caller id app
    - turning off auto network switch option in WiFi
    - factory reset phone, WiFi worked again then stopped after a while.
    Anyone know of a fix for this? Is it possible to downgrade to 4.2?
    tl;dr phones basically a potato without WiFi :/
    12-28-2013 04:02 PM
  1. Replies: 13
    Last Post: 08-06-2014, 03:37 PM
  2. Galaxy Note 3 - Bluetooth audio quality after update
    By polaraman in forum Samsung Galaxy Note 3
    Last Post: 12-31-2013, 01:38 AM
  3. Verizon LG G2 - Never go without a case
    By denarok in forum LG G2
    Last Post: 12-30-2013, 09:48 AM
  4. Sprint Galaxy Note 2 - voice prompt
    By Felix Figueroa in forum Sprint Galaxy Note 2
    Last Post: 12-30-2013, 06:59 AM
  5. Samsung Galaxy S3 - screen won't turn on
    By Gadi Ben-Avi in forum Samsung Galaxy SIII I9300
    Last Post: 12-30-2013, 05:42 AM
