07-18-2015 09:34 AM
139 ... 456
tools
  1. Leo G's Avatar
    you are genius vidness....its solve my problem without rooted or anything...thanks a lot
    I rooted my phone and it was a much better solution. With the package solution you had to think about it. With the root, you just use your phone like you are suppose to. As soon as it went to NG6 the problem got that much worse.
    01-09-2015 07:36 PM
  2. csmall2495's Avatar
    The Page Name and adding the folder with ES File Explorer did not work for me. I am on a S5 Active on Android 4.4.4 KitKat.
    All I want to do is move files to my SD card and the device is blocking everything.
    Any updated suggestions would be greatly appreciated.
    02-26-2015 12:30 PM
  3. soffpro's Avatar
    where are GOOGLE's responses on all of this? - there should be OUTRAGE at them developing a system that doesn't allow apps to write to SDcard or KITKAT phones will have to expand storage to look like bulky 70s mobile phones. WHAT ARE YOU PLAYING AT ANDROID? what a bunch of idiots!
    what sane person would buy any phone with KITKAT if they knew this was an issue? DUGHHHH! NO BRAINER. and now i resent you for buying an expensive phone and discovering you've been such idiots.
    02-27-2015 04:24 AM
  4. Leo G's Avatar
    Welcome to the world of Apple.
    02-27-2015 06:52 AM
  5. hollyoaks777's Avatar
    You will not believe me when I say this works. Use the built in my files and that's it no need for any other file explorer. Though I must say that I loved es file explorer.
    And another thing I found out today was that the new s6 is only coming with 2 apps no bloat ware at all .But 8f you hear a release date for UK please let me know. Thanks guys
    03-01-2015 11:50 AM
  6. Leo G's Avatar
    I rooted my phone to use this but it worked. NextApp SD Fix
    03-01-2015 12:19 PM
  7. Tim Peters1's Avatar
    The article "KitKat and SD cards — what's fixed, what's broken and what's misunderstood | Android Central" is not helpful. In summary, it states that Kit Kat secures the SD card and that likely breaks most apps trying to use it and there is nothing you can do about it. It does not offer a solution or workarounds. It also uses a term like huff and puff to make light of the frustrations this has caused. Every time I find a new app that could be useful, I find that some feature won't work. I tried to move the whole app to the SDcard too. For example, I installed HealthTracker today. I tried export to CSV file. It gives me a familiar error. "error writing "HealthTracker.csv, data export failed". I delete 9 out of 10 apps I try to install because they don't work fully. I am stuck with a tiny amount of internal memory and a nearly useless SD card. Is there any hack to "unsecure" the "security features" they added? I'm tired of borrowing my wife's phone to use my apps.
    Ok. Since I believe this is what you're really asking (you've probably already figured this out but here is the solution). For some stupid reason kitkat blocks you from using file manager apps to move files to your external SD card because it doesn't give them permission to write to it. If you open up "My Files" in your apps you will be able to write and move files to your external SD card. Hope this helped.
    03-01-2015 12:45 PM
  8. mcluvin737's Avatar
    I am rooted 4.4.2 stock sprint S4. I've used the SD card fix apps, created the android/data file on the SD card, and tried My Files. None of those work for me. When I delete or add a file to the SD card, it looks like it worked, but after reboot, the changes are gone, like they never happened.
    03-27-2015 03:36 PM
  9. Leo G's Avatar
    I'm rooted 4.4.2 stock NC5 Verizon. Used the SD Fix and it worked. Happy as a clam.
    03-27-2015 03:46 PM
  10. Major Henderson's Avatar
    I've been using Spreadsheet programs to keep track of my packing list for my vacations for years. Boy was I surprised to find that I could not save the edited spreadsheet back to the SD card. I kept looking at the macroSD card to see if there was a write protect switch of which I was previously unaware. Finally, one of the Spreadsheet programs gave me an error message stating that the present version of Android OS would not allow writing to the SD card. I think this is ridiculous. No wonder Samsung did away with the SD card slot on their new phones. What good would they be anyway?
    04-21-2015 03:15 PM
  11. Johnpeter Clinton's Avatar
    i cant able to transver my app to sd card =in my phone
    04-26-2015 09:36 AM
  12. assassen027's Avatar
    Sorry what i posted didn't work
    06-11-2015 06:40 PM
  13. GeertVc's Avatar
    I was shocked it worked. It's not suppose to be able to manipulate the card. But I've found that ES has a few tricks up its sleeve and can do a few things the others can't. I've been very pleased with it. Disappointed in Google for not giving the option to opt out of their draconian provision of no access to the SD card. They want you to purchase space in the cloud. Which is very doubtful I ever will as it is an insecure place.
    Downloaded and tried ES today because I saw it was working for you on KitKat 4.4. However, when trying to copy a file to the external SD card, it still won't work. A message popped up it would only work if the device was rooted, which is not what I want (to do).
    I was wondering how you did this working. Can you explain?
    07-18-2015 03:20 AM
  14. Leo G's Avatar
    It's been a long time since I did that. It did work. A few things it wouldn't do were rename files and sometimes move files.
    I have since rooted and ODINed back to 4.4.2. I used an App called NextApp SDFix to make everything work correctly again. I renamed the APKs that have to deal with updates. My phone will be stuck at 4.4.2 from now on. It's where everything worked like it did when I bought it with a few upgrades in between.
    07-18-2015 09:34 AM
139 ... 456
  1. S3 back to stock from bricked?
    By khigh65 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 05-17-2014, 12:42 AM
  2. Not enough stroge. Free up SD card and try again
    By wbe in forum Samsung Galaxy Note 10.1
    Last Post: 04-26-2014, 02:49 PM
  3. How to take good low light/indoor pictures?
    By Joe113 in forum Samsung Galaxy S5
    Last Post: 04-26-2014, 10:54 AM
  4. Can you root WITHOUT a computer
    By DCSholtis in forum LG G Pad 8.3
    Last Post: 04-25-2014, 02:25 PM
  5. What happened to my GPS???
    By Evilguppy in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-25-2014, 01:31 PM
