1. neekweez77's Avatar
    I dropped my phone last week, shattered the bottom corner and put some cracks in the screen. Don't know if its related, but yesterday when I was using my flashlight app, it kept freezing my phone. Had to battery pull and restart. Tried to uninstall that app and install a new one. Would not install and kept restarting itself. Also when I go to my storage setting, it restarts. I can't even view my photo gallery. I can using photos, but not gallery. any ideas? And I'm sure the damage will negate a manufacturer replacement even if it has nothing to do with its issues? Thanks.
    06-25-2015 12:53 PM
  2. B. Diddy's Avatar
    Welcome back! Do you have a microSD inserted? If so, unmount it (in Settings>Storage), remove it and reboot, in case the card got corrupted, or if the SD interface somehow got damaged.
    06-26-2015 12:35 AM
  1. LG G3 - Battery problems
    By shulman in forum LG G3
    Last Post: 12-27-2015, 04:42 AM
  2. Touchwiz home problems.
    By Tako Tan in forum Android 5.0 Lollipop
    Last Post: 06-29-2015, 08:43 AM
  3. how do I clear storage space
    Last Post: 06-27-2015, 12:34 AM
  4. Speaker problems on my Tab
    Last Post: 06-26-2015, 12:42 AM
  5. Replies: 0
    Last Post: 06-25-2015, 06:41 AM
