[THEME][PORT]Ice Cream Moment Ported to Slider
tylermich7
229
25
If you want to theme the drop down notifications toggels I give you permission to use my work from my ICS theme for the gelato ROM.
Also on mobile I can't download the .zip can you fix that or am I going to have to go old school and hop on the old laptop to download it to my sd?
Sent from my LG Optimus Slider running Gelato 11 28/ Gingerkernel7.1. Theme:ICS
raymix1000
159
13
is anyone else experiencing this issue? i would use dolphin browser. how does one theme the notification toggles?
tylermich7
229
25
Edit to my post. Just flashed it. I have some spare time tonight so ill do the edits to the notification bar and the quick panel. If anyone wants them just reply saying you do and ill post a link to the new .zip file for yous to flash.
raymix1000
159
13
you will receive credit.
tylermich7
229
25
Finished the work. I'm gunna flash it first on my device to check how it turned out.
Ill reply back in a few minutes.
tylermich7
229
25
Forgot to ask. How do you want the area header where is says "no notifications"
Do you want it rounded looking like it currently is. Or do you want the flat black ics look?
LeoLawliet
713
108
raymix1000
159
13
flat black ics look
LeoLawliet
713
108
OKAY GUYS, HERE IT IS. SHOULD BE JUST WHAT YOUS WANTED. if you want me tweak anything let me know and ill try and get to as soon as i have some spare time.
https://docs.google.com/open?id=0BxcYAc0IApeUYW10enF5eVRSMkk :)
It just shows the files seperately, not the entire flashable zip. Anyway you can upload it to like Mediafire? Thanks :)
raymix1000 Can you edit the first post? The blue signal bar does in fact work on Mobster Rom. I just thought I'd point that out.
Edit: I see the changes nvm thanks
Sent from my LG-VM701 running Mobster Rom via Tapatalk
tylermich7
229
25
There should be an option in the corner that says something like show original or something. Click that then download.
Reactions: LeoLawliet
LeoLawliet
713
108
There's a slight issue with the notification bar, when it's swiped all the way down in landscape the image is a bit distorted, I'll try to take a screenshot and show you what I mean. Other than that, the sound and orientation toggles on the notification are blacked out when they're disabled.
The circle battery was a great addon, that should definitely stay. If you're going for more of an ICS look then maybe a clear black notification dropdown or background would be a great addon, along with the grey menus from ICS.
Edit: Screenshots
tylermich7
229
25
Oh . My bad. I never noticed that before. Reason cuz I never ever use my phone in landscape. The bar is set to the mdpi screen res. I personally wouldn't know how to have oit where it looks good in vertical and horizontal modes.
LeoLawliet
713
108
I'm not sure how to do it either, I'm pretty OCD when it comes to details so I just thought I'd point out things that seem even just slightly out of place. Is this all done through the online theming kitchen? (Not sure is that's what it's called)
Sent from my SGH-T839 using Tapatalk
raymix1000
159
13
the easiest way is to hit ctrl+s
raymix1000
159
13
no i went through the apks and individually transported them to this theme. i think its safe to say tylermich7 did the same
kirk781
