Port your cell number to Google Voice and do your texting through it using data only... then hang around a lot of open wifi hotspots...
What about voicemail - do they integrate with Google Voice seamlessly? VMo doesn't let you forward unanswered calls to Google Voice... I'm very interested!
You need to read more about how this deal works. The republic phone is designed to take advantage of wifi anytime it can.. automatically. Then it routs all voice, text, and data through the wifi instead of through the cell.
The limits imposed by republic ONLY apply to what's being transmitted through cell. In other words, if you're in a wifi zone and send 1000 texts and then go outside of the wifi zone and send 20 texts, then only those 20 texts count against your "limits".
The whole operation is supposed to be seamless to the user.
It sounds pretty smart to me. I've heard of people buying the V and not even bothering to activate it - and using it for communications only through wifi. IIRC even unactivated phones by law have to work with 911 calling so emergency calls are taken care of too.
It seems to me the $20/month republic deal is a nice compromise for those who don't want to spend a lot of money and for those who don't want to be without service.
For those people complaining about data speeds I have to ask... WHAT THE HECK DO YOU USE YOUR PHONE FOR?! Really if 3G speeds aren't good enough then you really must be downloading a lot of crap.. or tethering - either way even the Virgin plan isn't going to be good enough for you!
