1. adamhos's Avatar
    Most of my contacts have been linked to my email (exchange through work), I'm wondering if there is a way to switch them to my gmail instead. Anyone ever had to do this?
    Thanks
    08-07-2012 01:29 PM
  2. ThatGuyLurkin's Avatar
    You could backup the contacts, add a gmail account and sync them.
    Maybe even resync the Gmail account while Exchange is still on.
    adamhos likes this.
    08-07-2012 01:59 PM
  3. adamhos's Avatar
    Thought I tried that, ill try again
    08-07-2012 02:20 PM
  4. cole2kb's Avatar
    Are you able to export your contacts from Exchange into any sort of file? I believe Google lets you import them (via GMail on the web) from a CSV file.
    adamhos likes this.
    08-07-2012 02:29 PM
  5. adamhos's Avatar
    For those interested, I was able to export contacts to SD where it created a .vcf file, when I clicked on the file through file manager it I was able to sync with all my accounts.
    Thanks for the advice
    08-07-2012 03:35 PM
