Disabling Virgin/Sprint's Bandwith Throttling [TUT/TEST]
teki9
22
3
This Stops Sprint's and Maybe Virgin Mobile's Bandwidth Throttling issue when using Pandora/Skyfire/Skype/Last.FM/etc
Get your MSL#
Easy way to get your MSL #: Easy way to get your MSL # - PPCGeeks
Go to phone > Dialer > ##3282# > Multimedia > Enter "MSL" > You will see RTST Proxy, HTTPPD Proxy > modify every list > set Address with "0.0.0.0", port with '0'.
I would copy down original #'s just in case you want to revert back for some reason!
I haven't tested it enough to know what Sprint is blocking/filtering/throttling and why. There are several potential reasons including:
- The proxy may be throttling bandwidth. Since 32k aac+ uses a very modest amount of bandwidth, you may be ducking under a threshold.
- The proxy may be doing site-based filtering. Perhaps the site you're connecting to isn't covered.
- The proxy may be doing content-based filtering. aac+ isn't as well supported as other streaming media. Perhaps it is being overlooked.
- The proxy may be overloaded with connections, and dropping higher bandwidth streams.
This is pulled from: Forum.ppcgeeks.com
Now does it work for the Optimus V?
We have to, since we are using Android: Go into settings, and update the Proxy from there.
Does it work for you? It did for me, speedtest posts in a day or 2.
tremulos
8
i did this on a few phones on sprint. they throttle streaming video and other downloads after doing this fix it also sped up my phone a bit and all my internet apps became snappier
anon(141613)
73
5
I got into the info screens via the long method at PPC Geeks on my V after the short method failed, but the MSL line is not listed/available via that method. On my V, at least.
I do find it interesting that one of the three ril lines listed, however, is:
[ril.proxy.bypass]: [true]
mikeladue
13
Same here . . . no MSL listed.
scoutconnor
101
6
Same here.
I am also unable to get ##DATA# to do anything other than try and dial a real number.
r00t
171
13
I was browsing the files on the Optimus V through adb shell and I came across these strange hidden apps installed on the phone:
$ adb shell
# ls /system/app
SprintHiddenMenu.apk
LgHiddenMenu.apk
HiddenMenu.apk
So naturally I Googled it, specifically LgHiddenMenu.apk, and came across this tutorial to force roaming. Accessing the LgHiddenMenu gave me these really advanced configurations and testing for this phone. I think you guys might be able to access the proxy configuration through this. I haven't played around with it much yet.
r00t
171
13
$ adb shell
# ls /system/app
LgHiddenMenu.apk
HiddenMenu.apk
I can access it via the short cut > Data (all the way down) > Multimedia, but it asks for a service code. Failing to enter the right one reboots your device.
gfurr24
Active member
Jan 30, 2011
29
8
I wonder what would happen if you deleted that LGHiddenMenu.apk? I saw this while exploring using Root Explorer and was a little disturbed by it as well. But if you say that it forces you into roaming, now thats a little disturbing.
dchawk81
619
31
It made no difference whatsoever on my Epic. Then again, the bottom two were already zeroed.
idbl_fanatic
171
16
What long method?
nerdmastax
101
3
i called virgin mobile and they said its aginst their policy to give it out and that its purposely blocked on the phone... so we need to rip it out of it by force...lol
kerokekerol
