1. joewknap's Avatar
    i press vol down home and power like the instructions say and all i get is a black lit up screen. i tried using command prompt to boot to recovery and it stays stuck on the lg bootscreen as does ROMtools reboot into recovery. whats my problem? thanks in advance for any help
    03-06-2011 08:41 PM
  2. adeelmysore's Avatar
    Are you plugged in when trying to goto recovery that usually is the problem. If not try pulling the battery pop it back and use the power down and home button. Last I would reflash the recovery.
    03-07-2011 12:27 PM
  3. joewknap's Avatar
    Problem solved. Thank You!!! Now i just have to figure out how to get gingerbread on this thing. Again Thanks So Much!
    03-07-2011 07:33 PM
