1. AC Question's Avatar
    when i get a msg on whatsapp the LED light is not flashing at all.
    all the setting on whatsapp and on the device setting are on and it should work.
    i use IG G4, android 5.1, V10b
    08-19-2015 12:17 AM
  2. Ravit B's Avatar
    any ideas please?
    08-23-2015 01:33 AM
  3. killedby91's Avatar
    I never heard something like this. Are you sure your flashlight is working ?
    08-27-2015 08:22 AM
  4. Ravit B's Avatar
    flashlight? of course. But i'm talking about the LED not the flashlight ..
    08-29-2015 11:18 PM
  5. redlinecoatings's Avatar
    On your phone settings is only the notification led on with it checked off for downloaded apps only? If not they could be conflicting. I use led blinker personally and it works flawlessly.
    08-30-2015 06:24 AM
  6. Ravit B's Avatar
    "downloaded apps" was off!!! it works now, thanks!!!!! )))
    Edit - now i have a different problem - the LED wont stop flashing even after i read the msg..
    08-31-2015 02:19 AM
  7. redlinecoatings's Avatar
    Strange. Try setting it all up and reboot the phone.
    Sent from my Nexus 6 using Tapatalk
    08-31-2015 08:31 AM
  8. Ravit B's Avatar
    I saw it is a known issue, no real solution yet..
    09-01-2015 06:12 AM
  9. redlinecoatings's Avatar
    Have you tried led blinker for your notification lights? I use it and it works flawlessly.
    09-01-2015 06:49 AM
  10. Ravit B's Avatar
    i did not understood your question..
    i can not post link to explain the problem..
    09-01-2015 08:23 AM
  11. redlinecoatings's Avatar
    Have you tried using a third party app to control your led light?
    09-01-2015 08:51 AM
  12. Ravit B's Avatar
    no i did not.
    09-01-2015 09:21 AM
  13. redlinecoatings's Avatar
    Try using the app LED blinker pro. Works perfect on my G4.
    09-01-2015 11:24 AM
  14. Ravit B's Avatar
    thanks for all your help!
    09-01-2015 12:49 PM
  15. redlinecoatings's Avatar
    No problem.
    09-01-2015 01:41 PM
  1. Gear s and not receiving notifications
    By castone001 in forum Samsung Gear S
    Last Post: 08-25-2015, 05:24 PM
  2. GS6 vs Lg G4
    By Cooldrewf in forum Samsung Galaxy S6
    Last Post: 08-19-2015, 08:18 PM
  3. Replies: 1
    Last Post: 08-19-2015, 12:02 AM
  4. My Samsung smart switch doesn't work! Why not?
    Last Post: 08-18-2015, 10:12 PM
  5. Does Helium Backup work for you guys?
    By maximus96 in forum Samsung Galaxy Note 5
    Last Post: 08-18-2015, 09:45 PM
